Best 16:9 Screen size for 12x22 room? - AVS Forum | Home Theater Discussions And Reviews
Old 05-31-2001, 08:12 PM - Thread Starter
jstolzen's Avatar
Any opinions on what 16:9 size would be better for a 12x22 room w/LCD front-projection: 106'' (52x92) or 119''(58x104) diagonal?
I'm considering either the Sony 10HT or Sanyo PLV-60 - both 16:9 native mode projectors - tho some say the Sanyo has better contrast and black levels.
Seating can be anywhere that I don't see pixelization/artifacting..I'm considering 13' for first row, 18' for second tho I would like to shorten this if possible.
I'm leaning toward the Da-Lite High Contrast (after reading the comments/reviews here) over the Stewart Greyhawk.
jstolzen is offline
Old 05-31-2001, 09:25 PM
lro
lro's Avatar
I have the same size room,I'm using a 60X106,home made with masking for 2:35 AR,first row is at 14' second row is at 18'.
lro
lro is offline
Old 06-01-2001, 07:43 AM - Thread Starter
jstolzen's Avatar
Thanks, LRO!
What kind of projector are you using?
Do you see any pixelization or artifacting at 14'? How bout 13'? (And, are you using a depixelization lens or anything else fancy?)
jstolzen is offline
Old 06-02-2001, 06:55 AM
lro
lro's Avatar
I'm using an AMPRO 3600 CRT projector with an HTPC and I don't see any change until I'm about 2' from the screen.
lro
lro is offline
