Gray screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-29-2001, 11:52 AM - Thread Starter
Ryan0751's Avatar
I continue to read that a gray screen will vastly improve black levels and color accuracy with a DLP projector. Namely, many people are using the Stewart Grayhawks. I wandered to their site, but I couldn't find pricing. Currently I have a pull down Dalite Matte which screen, and it tends to curl. I'd be interested in a nice fixed mount style screen, with a wide black border to hide the halo effect of my DLP. How much is something like this? I've heard they can get pretty expensive, but I really have no idea where to look...
Ryan0751 is offline
post #2 of 8 Old 05-30-2001, 11:40 PM
ggolamco's Avatar
You might want to consider e-mailing Jason Turk directly at the AV Science Store: Jason@avscience.com He's usually very responsive, and AVS is an authorized Stewart dealer.
Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
ggolamco is offline
post #3 of 8 Old 05-31-2001, 04:17 PM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
Try cousinsvideo.com You can get a Da-lite high contrast gray screen in a fixed model for around 500.00 delivered. Excellent picture. If you would like a Grayhawk, do indeed contact Jason as they have the best prices.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #4 of 8 Old 06-04-2001, 07:30 PM
Jonmx's Avatar
I am about to get the Da-Lite High Contrast De-Mat 106" 16:9 screen in a permwall for use with a Sanyo XP18N for about $500. I hear the Greyhawk is quite a bit more expensive, but haven't seen a price. Is the Greyhawk that much better? I know the greyhawk is a higher gain (0.6 vs. 0.95), but with 2000 lumans, I think the Da-lite will give me a more pleasing image. Am I off base and is that the tradeoff between the Da-lite and the Steward grey screens?
Jonmx is offline
post #5 of 8 Old 06-04-2001, 08:54 PM - Thread Starter
Ryan0751's Avatar
I just bought a da-lite high contrast 80x45 16:9 screen myself. The screen, with shipping, is about $400. The price for a grayhawk of that size is around $900. From what I've read on here, the dalite material is very similar to the grayhawk, but the grawhawk has a better build quality. For me, I couldn't justify the difference in price.
Ryan0751 is offline
post #6 of 8 Old 06-05-2001, 12:33 AM
KFung's Avatar
The Greyhawk is not at all like the Da-Lite. I think Don Stewart elaborated on this in a previous post (it was only a few days ago too...). Anyways the Da-Lite grey screen is just a matt gray screen, whereas the Stewart Greyhawk has an optical coating to increase it's gain. The gain of the base coat of paint in the Greyhawk is comparable (if not darker) to the gain of the Da-Lite grey. This reduces the amount of light bouncing around the room and absorbs reflected light off the walls and the optical coating means that there is a smaller brightness penalty than the Da-Lite. The screen is also less susceptible to ambient or reflected light off-axis.
The Greyhawk is definitely worth considering despite the formidable price difference. Get a sample and let your eyes decide! (although you won't get the full benefit without a full screen test)
Kam Fung
edit- Found the link
http://www.avsforum.com/ubb/Forum9/HTML/001055.html
[This message has been edited by KFung (edited 06-05-2001).]
KFung is offline
post #7 of 8 Old 06-05-2001, 11:44 AM
JeremyJ's Avatar
Does anybody have any idea what this "optical coating" might be, or how it might be duplicated. My installation is rather unique thus requiring a DIY. Otherwise I would save up for a Greyhawk.
Jeremy
D-ILA, HTPC, HDTV, Panamorph(?)
"Done the Impossible" a Firefly Fan Documentary. www.donetheimpossible.com
JeremyJ is offline
post #8 of 8 Old 06-08-2001, 05:40 PM
KFung's Avatar
I have no idea what the optical coating is, I imagine that each manufacturer closely guards the composition of the coating they use to obtain gains above a matt screen. What is so special about your installation? I know Stewart custom manufacturs all their screens, they may be able to accommodate your needs.
Kam Fung
KFung is offline
Closed Thread Screens
