The Silver Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-23-2001, 04:51 PM - Thread Starter
deronmoped's Avatar
I'm using silver paint on my screen which gives me about 2.5 gain.
Does anyone know of a brighter screen material out there besides Stewart's silver screen material at $25.00 a square foot and Vultec which won't sell there silver material?
This is for a ceiling mounted projector.
Thanks Deron
Surfs Up!
CRT Videophile
deronmoped is offline
post #2 of 4 Old 06-25-2001, 08:11 AM
Colin's Avatar
What does the silver painted screen look like. Other than hotspotting which I assume is dependent on angle of incidence and reflection what does the image look like?
Colin
Colin is offline
post #3 of 4 Old 06-25-2001, 10:55 PM
REW
REW's Avatar
Please send me a bunch of Novabeam curved screens,recycling is the answer.
http://www.avsforum.com/ubb/smile.gif
Ron
"Your priorities will be different-its the weighting that counts!"
Ron
"Your priorities will be different-its the weighting that counts!-only if its done by FET!"
REW is offline
post #4 of 4 Old 06-28-2001, 10:31 PM - Thread Starter
deronmoped's Avatar
I like the image I ended up with a lot, its bright, no hot spotting that you can detect, when playing a movie, the colors look very good. I would highly recommend it if you are going with a big screen.
Deron
Surfs Up!
CRT Videophile
Closed Thread Screens
