Screen Construction - AVS Forum | Home Theater Discussions And Reviews
Old 07-02-2001, 07:37 AM - Thread Starter
MI6
MI6's Avatar
Does anyone have any information on screen construction ?. I have purchased the screen, Da-lite and have constructed a frame, now I am wondering about the
best way to attach it to the frame. Direct would be one way via velcro around the edges, another would be to construct a second frame for the screen and have the first go over the
second. Any thoughts anyone, much appreciated
MI6
MI6 is offline
Old 07-02-2001, 05:48 PM
Mark Lopez's Avatar
M16,
I suggest you do a search for "mounting" using the search button above. There are many threads on this subject.
Mark Lopez is offline
Old 07-04-2001, 02:21 AM
Gunnar's Avatar
Quoted: 13 Post(s)
I used staples to attach Draper M2500 material to a wooden frame. The M2500 material is rather flexible, and the screen have stayed flat and nice for about a year. I put some double sided tape on the frame before stapeling to prevent the material from ripping.
I will probably replace the material due to hotspotting and color shift.
Gunnar
Gunnar is offline
