Aspect ratio formula? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-05-2001, 01:48 PM - Thread Starter
Sambryan's Avatar
Is there a formula at determine aspect ratios? I want to make a screen that is 1.78:1. I still need to determine how wide or tall I need to make it. I was just wondering if there was a formula so I could plug my numbers in.
The Dude Abides.....
Sambryan is offline
post #2 of 4 Old 07-05-2001, 02:15 PM
LeeAntin's Avatar
This is a trick question...right? Just multiply the desired height of your intended screen by 1.78 to get the width.
Example: 4 feet high would result in 7.12 feet wide so the measurements would be 4 x 7.12 feet.
Lee
LeeAntin is offline
post #3 of 4 Old 07-06-2001, 03:30 PM
smitty's Avatar
Try this calculator: www.sonydisplaysystems.com/display/downloads.html
It's for Sony projectors, but it allows you to plug in aspect ratios and get all the screen measurements.
[This message has been edited by smitty (edited 07-06-2001).]
smitty is offline
post #4 of 4 Old 07-06-2001, 10:50 PM
BurkeLaShell's Avatar
Then, to get the diagonal, take the square root of the width squared plus the height squared.
sqrt(4^2 + 7.12^2) = 8.17 feet (98 inches)
--Burke
BurkeLaShell is offline
Closed Thread Screens
