Switching for Electric Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-06-2001, 06:11 PM - Thread Starter
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
I am installing a Stewart Electric Screen and would like a couple inputs on how any of you have handled the up/down switching. I am using X-10 for my lighting controls and would like to use the same for raising and lowering the screen. Options are to run the wires back to a relay box in my rack area or put a hidden box up next to the screen (not sure I like that) or do some combination where I have low voltage lines running from the rack to the screen and then do the 120 volt switching at the screen.
Suggestions??
Thanks...Doyle
M&K S150THX LCR, SS150THX Tripoles, 4 Speakercraft Aim-7 for Atmos
B&K AV5000 driving the M&Ks
Denon X4300H AVR
"So many tweeks....So little time!"
DoyleS is offline
post #2 of 4 Old 07-08-2001, 09:52 PM
dpearson's Avatar
Doyle,
Check out this thread...my screen still works fine after almost a year with this config. Just make sure that your screen cuts the power in both the up and down positions.
http://www.avsforum.com/ubb/Forum9/HTML/000334.html
Good luck.
-David
dpearson is offline
post #3 of 4 Old 07-11-2001, 12:23 AM
I'mListening's Avatar
David, This sounds great! I want to do this setup for my new Da-Lite screen. You didn't go into detail on the transformer, however. Where did you purchase this 12V unit?
Darren from Kansas City
Thanks for reading!
Darren Mortensen
Cinema At Home: A/V Interior Design
I'mListening is offline
post #4 of 4 Old 07-11-2001, 06:42 PM - Thread Starter
DoyleS's Avatar
Quoted: 35 Post(s)
Liked: 25
Thanks David,
This was one of the ways I was considering using. Essentially the limit switches on the screen shut the power off in each direction. Since the screen motor is a 120 volt motor, it probably makes sense to have some sort of master switch in line with the power going to the screen or else even when you go to service it you will still have power applied.
Darren,
The transformers are available at most electrical supply stores or even Radio Shack for less than $10.
Denon X4300H AVR
DoyleS is offline
Closed Thread Screens
