How to clean pull-down projector screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-04-2001, 07:44 PM - Thread Starter
Derek173's Avatar
HI, I'm new here. I just acquired a projector and a pull down screen. The screen is pretty dirty and I was wondering how do I clean it? Soap/water? Windex?
Derek173 is offline
post #2 of 4 Old 06-05-2001, 09:07 AM
TGroom's Avatar
What kind of screen is it? Do you know the make and model? Some can't be cleaned, glass-beaded for example.
Tim
TGroom is offline
post #3 of 4 Old 07-04-2001, 02:12 AM
luvmytivo's Avatar
if it's just dusty, swiffer cloths work great..
Darren Rogers
Darren
luvmytivo is offline
post #4 of 4 Old 07-12-2001, 04:50 PM
bhadsell's Avatar
As mentioned previously, if the material is glass beaded, all you can do is carefully dust the surface. Any attempt to clean it will take the beads off the surface.
It the material is a matt white, you can use a mild solution of water and soap. A mild dishwashing liquid such as Ivory is best - nothing with abrasives or wax.
I would suggest you test a small corner first.
Bob Hadsell
Home Theatre Sales Manager
DRAPER, Inc.
Bob Hadsell
DRAPER, Inc.
bhadsell is offline
Closed Thread Screens
