What Screen for CRT? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-14-2001, 02:33 AM - Thread Starter
Jon Eivind Lygren's Avatar
I have a Barco Graphics 808 with a EuroScreen 1.8m screen. The problem is that the screen is not uniform, and therefore gives bad results in moving scenes. I have a girlfriend that is very opposed to a mounted screen, so a roll-down is my only alternative. I have heard Steward has some good ones; are they uniform even when they are roll-down types?
Besøk www.AVforum.no/se/dk
Nordens Beste Audio/Video Forum!
Jon Eivind Lygren is offline
post #2 of 2 Old 07-16-2001, 07:34 AM
Andrew Low's Avatar
If you can afford it, a tab tensioned roll down will give you very good results.
Consider the other two screen companies as cheaper alternatives, but you get what you pay for. Stewart has a strong reputation for a reason.
Roo
Andrew Low is offline
Closed Thread Screens
