Luminous white for every wall? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-20-2001, 06:21 AM - Thread Starter
FaithInMe's Avatar
I need to repaint my living room, and was wondering if using the Sherwin Williams Luminous White for all four walls and ceiling is too bright?
I plan to project on the wall. Maybe in the future, I will get a screen, but it might be a while before I do.
thanks
FaithInMe is offline
post #2 of 2 Old 07-20-2001, 08:19 AM
KFung's Avatar
Painting all four walls and ceiling "luminous white" will not give you good results. You'd only want to paint the wall you are using as a screen white, the other walls "should" be a dark colour, but that may not be acceptable. Painting the other walls white will reflect light from the screen back onto it, washing it out.
KFung is offline
Closed Thread Screens
