Difference between Da-Snap, Imager, & Cinema Contour. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-19-2001, 10:08 PM - Thread Starter
VPC
VPC's Avatar
Could somebody please help me identifying the differences between these frame types from Da-Lite?
I think Da-Snap uses velcros to attach the screen fabric to the frame, am I right?
But what about Imager and Cinema Contour?
VPC is offline
post #2 of 5 Old 07-20-2001, 07:33 AM
Blake Brubaker - Da-Lite's Avatar
VPC,
Please allow me to take a minute and answer your question. In order of their placement in our product line here are the differences between the Da-Snap, Imager and Cinema Contour.
Da-Snap
This screen is a basic 1-1/2" square framed screen where the surface is attached to the back by snaps. Since the surface is attached to the back of the frame, the frame itself makes up the border around the screen surface. The frame comes standard with a matte black powder coated finish. However, a velour-like finish we call "Pro-Trim" is available as an option.
Imager
This screen has a 2" frame that is designed with a rounded front face much like simple trim mold you would see around an interior door in a house. The screen surface is attached to the frame by means of Velcro. The attachment point for the surface is inside the frame. Basically, the frame looks like a sophisticated "C" and the surface attaches to the inside of the "C" that is located closest to the front of the frame. (Hope that makes sense) This frame too is standard with a black powder coated finish and the Pro-Trim finish is an option.
Cinema Contour
The frame on this screen is the largest of the three and is considered to be the most Hi-End. The dimensions of this frame are 3" Wide and 1-5/8" Deep. Therefore, it provides more of a border around the screen. Much like the Da-Snap the surface is attached to the frame via snaps and the frame itself creates the border. The unique thing about this frame is the fact that the outer 1-1/2" is flat an then the inner 1-1/2" is angled back towards the screen surface. This helps eliminate any shadows and provides clean lines back towards the screen surface. This frame too is standard in a matte black powder coated finish and the Pro-Trim is an available option.
All three of these screens have the same surface options. The options range from a 0.8 gain grey fabric we call HC Da-Mat (designed for high output LCD and DLP projectors) to 1.5 Gain Pearlescent. In between those two you will find a 1.0 gain Da-Mat fabric and the ISF approved 1.3 gain Cinema Vision Surface.
If you have further questions, please let us know at Da-Lite. We would be happy to assist.
Also, a few of links you might want to look at are:
http://www.da-lite.com/products/spec...ail&spec_id=23
http://www.da-lite.com/products/spec...tail&spec_id=9
http://www.da-lite.com/products/spec...ail&spec_id=63
Best regards,
Blake Brubaker
Director of Home Theater Sales
Da-Lite Screen Company, Inc.
[This message has been edited by Blake Brubaker - Da-Lite (edited 07-20-2001).]
Blake Brubaker, CTS
Vice President of Sales
Blake Brubaker - Da-Lite is offline
post #3 of 5 Old 07-20-2001, 08:52 AM - Thread Starter
VPC
VPC's Avatar
Thanks, Blake!
I wonder if you have any close-up pictures of these frame types available on the web somewhere. It's impossible to discern the differences from the links provided in the previous post.
VPC is offline
post #4 of 5 Old 07-20-2001, 12:34 PM
VPC,
No unfortunately, we do not have any close ups on the website. However, if you want to send me your e-mail address I will try to take some digital shots and send them to you.
Blake
Blake
Blake Brubaker, CTS
post #5 of 5 Old 07-20-2001, 01:06 PM - Thread Starter
VPC
VPC's Avatar
Thanks again, Blake! I appreciate your help.
My e-mail address is gowplforms@yahoo.com
VPC is offline
Closed Thread Screens
