Horizontal Masking Control ? - AVS Forum | Home Theater Discussions And Reviews
Old 07-18-2001, 08:15 PM - Thread Starter
Fireball's Avatar
For Stewart screens without the smart stop motor mechanism (has four memories/stops for different aspect ratio control of the masking system), has anyone developed a way to easily manipulate the masking system to change aspect ratios? i.e..press a single button and the masking system changes to the desired aspect ratio.
Fireball is offline
Old 07-20-2001, 08:37 AM
Deane Johnson's Avatar
I have done so quite successfully, however the motor drive units from are no longer available.
Here is a link to my site that has details and diagrams on how it was done in case it gives you any ideas for trying something else.
Just scroll down and click on "masking system".
http://www.kathiejohnson.com/HomeTheater.html
Deane
Deane Johnson is offline
Old 07-20-2001, 07:04 PM - Thread Starter
Fireball's Avatar
Deane:
That is quite a system you developed. It looks like it works very nicely.
I was looking at the Stewart masking systems. There is a $1700 price difference between the masking screens that have one memory vs. 4 memories for multiple aspect ratios. As long as the Stewart motors move slowly enough, I bleieve that a small controller could handle the two motor drive mechanisms. It just seems like a lot of work to do it this way.
Fireball is offline
Old 07-21-2001, 07:18 AM
Mane3215's Avatar
Awesome masking system setup. I think I will try and tackle this one myself =).
Mane3215 is offline
Old 07-21-2001, 09:22 PM
One thing that doesn't show in the diagram are the side panels or masks. These are frames made from 1x2 lumber with black velvet stretched over them. The end result is that the picture is completely surrounded by deep black. The speakers are mounted on the wall and the side frames have cutouts for them. Becuase everything is black, nothing shows.
I hope to develop the site further to show these things. It's a tragedy that the DrapeBoss motors are no longer available. They were perfect with their 8 programmable stops. Each button on the X-10 remote control can be a different aspect ratio, and randomly accessible.
Maybe someone will bring them back on the market.
Deane
