Loch Screens/What Should I Do? - AVS | Home Theater Discussions And Reviews
post #1 of 13 Old 04-23-2015, 04:57 PM - Thread Starter
Liked: 0
Question Loch Screens/What Should I Do?
Hi,
Does anyone have any experience or thoughts on these high contrast grey screens by Loch? I'm specifically looking at the Loch High Contrast 92'' diagonal Manual Projector Screen with Slow Retraction. The specs and price are attractive to me – does it sound too good to be true?
amazon.com/LOCH-92-diagonal-Projection-Retraction/dp/B00DV1J4ZM
My setup isn't ideal -- small apartment room with white walls. I only watch movies at night with the lights off.
Projector is a Benq W1070. The piicture looks great in dark scenes as well as bright scenes (nintendo video games and classic high-key technicolor movies look amazing), but get's washed out by ambient light in high contrast scenes with both a lot of white and black. Screen budget is less than <$100.
I need a 90"-95" manual screen. I imagine the screen needs to be grey to fight washout. Will a grey screen suffice, or do you think it needs to have some sort of ambient light rejection/retroreflectivity too?
Should I:
a) Go the easy route and buy the Loch screen.
b) Buy a cheap manual white screen and DIY paint it
c) Attempt to find a used 92" Panoview Graywolf II
Are there other brands that I should look into with manual screens in my size range and budget?
moire is offline
post #2 of 13 Old 04-24-2015, 11:24 AM
Quoted: 61 Post(s)
Liked: 9
In my experience most grey screens do not improve contrast; they make the black look darker but cut down on the whites at the same time. From your description it appears that the washing-out is primarily caused by reflections off the white walls from the projected image itself. I would say your third option of buying a used GrayWolf would make the most improvement to the contrast, assuming you're not bothered by the "sparklies".
Dominic Chan is online now
post #3 of 13 Old Today, 12:08 AM - Thread Starter
Liked: 0
I was wondering if the Loch high contrast gray material could be the same as Elune 1.1 Cinema Gray -- both screens have very similar product pictures, are manufactured in china, and have almost identical specs. The Elune, Graywolf, and Loch manual screen cases all appear to be identical. The remotes for the electric screens are the same design. I was in touch with a Elune representative about having their 1.1 Cinema Gray shipped to the US (they don't ship the cheaper manual screens here), and asked them if they shared a manufacturer with the loch screens, but the representative declined to answer. It would make sense that they wouldn't want to if it were true, given that the Loch screens are considerably less expensive.
I'm still unsure what I should do: I went ahead and ordered the Loch screen, but I also serendipitously found a Graywolf I screen over the weekend on craigslist, and I'm relatively happy with the performance. The washout from the reflected ambient light is 100% gone, and the color/contrast is great. The texture of the screen is definitely noticeable in some situations, as expected, but something I could potentially live with. I think the appearance of the texture becomes less noticeable viewed off axis, and the brightness reduction isn't a problem paired with the lumens of the w1070.
I'm faced with the dilemma of refusing the package, or opening it to test it out, potentially having to pay $40 for return shipping or reselling the Graywolf on craigslist (which shouldn't be hard given the price I found it at).
My imagined cons of the Loch screen: Inferior ambient light rejection (how much, I have no idea) and worse white clipping
Cons of the Graywolf: Texture
Any thoughts would be much appreciated! If I end up opening the Loch screen, I'll let everyone know how the two screens stack up!
moire is offline
post #4 of 13 Old Today, 05:30 AM
Quoted: 61 Post(s)
Liked: 9
My imagined cons of the Loch screen: Inferior ambient light rejection (how much, I , have no idea) and worse white clipping
I don't know anything about Loch screens, but in general the lower gain, non-directionalal grey screens will not give you any real ambient light rejection capability. If you can live with the occasional texture of the GrayWolf screen, I would say keep it.
post #5 of 13 Old Today, 10:30 AM - Thread Starter
Liked: 0
Doesn't the positive gain of the grey loch screen indicate a non-lambertian reflectence, which would means some ambient light rejection?
moire is offline
post #6 of 13 Old Today, 11:00 AM
Quoted: 61 Post(s)
Liked: 9
If you look at the Elunvision Cinema White and Cinema Grey screens as "representative" examples, there's essentially no difference between the two, when it comes to ambient light rejection ratios between white and grey screens:
http://elunevision.com/cinema-white.html
http://elunevision.com/cinema-gray.html
Compare these to their Pro Cinema Grey, which is the same as the GrayWolf:
http://elunevision.com/pro-cinema-gray.html
post #7 of 13 Old Today, 11:06 AM - Thread Starter
Liked: 0
If you look at the Elunvision Cinema White and Cinema Grey screens as "representative" examples, there's essentially no difference between the two, when it comes to ambient light rejection:
Those spec sheets say that the white has an 81% ambient light reflectance value, and the gray reflects even less ambient light at 67%, no? Makes me wonder whether I should have gone with a white screen –– I imagine the white wall I was projecting on reflects ambient light even worse.
moire is offline
post #8 of 13 Old Today, 11:11 AM - Thread Starter
Liked: 0
Thanks for pointing me to these spec sheets. I guess ambient light reflectance value of the Graywolf is 51%, and I suspect that its ambient light rejection properties are overkill for my needs, where I'm only trying to fight the ambient light reflected off of my white walls. I think I'll give the screen being shipped to me a shot.
moire is offline
post #9 of 13 Old Today, 11:18 AM
Quoted: 61 Post(s)
Liked: 9
These are light reflectance values, which obviously will be lower for the grey screen. If you look at the actual curves, the ratio between 0-deg gain and 80-deg gain are:
Cinema White: 1.2/0.86=1.39
Cinema Gray: 1.1/0.79=1.39
The ratio for the Pro Cinema Gray is 1.8/0.63=2.86
post #10 of 13 Old Today, 11:26 AM - Thread Starter
Liked: 0
I believe you're incorrect, those graphs do not describe "ambient light rejection" as a property, they simply are mapping the gain over the viewing angle. Gain refers to how much light is reflected w/ respect to a lambertian surface. The Vivid Pro Cinema Gray will reflect much more light back at the viewer than either the Cinema White or Cinema Gray, yet it has the lowest Ambient Light Reflectance value because it has the highest "ambient light rejection" (which is not a real metric).
A gain of higher than one indicates that more light is being reflected back in the direction of its source, instead of being diffused evenly at all angles, which is essentially ambient light rejection.
moire is offline
post #11 of 13 Old Today, 12:40 PM
Quoted: 61 Post(s)
Liked: 9
Yes, these curves indeed show how the gain varies with the viewing angle.
Note, however, an ALR screen only rejects ambient lights coming at an angle, and it works by having a higher gain at 0 degrees and a lower gain at steeper angles. It has no other way for distinguishing between the projected light and the ambient lights.
Thus, you can tell a lot about the light rejection capability of a screen by looking at its gain-vs-angle plot. A lambertian surface (with a uniform gain for all angle) will have NO ambient light rejection capability. Conversely, a screen with a steep curve (such as the Pro Cinema Gray) is very effective for ambient light rejection.
post #12 of 13 Unread Today, 01:07 PM - Thread Starter
Liked: 0
Yes, and neither the Cinema White or Gray screens are lambertian surfaces, and it appears that they will exhibit some ambient light rejection properties as shown by the slope of the curve on their spec sheets. The Ambient Light Reflectance value also indicates that the Cinema Gray reflects less ambient light at the viewer than Cinema White, and the Vivid Pro Cinema Gray reflects the least ambient light. Looking at the gain-vs-angle plot seems helpful in evaluating ambient light rejection ability, but I don't think showing that the ratios between the highest and lowest gain on the Cinema White and Gray are the same indicates much -- of course they're equal, the slope is the same.
moire is offline
post #13 of 13 Unread Today, 03:10 PM
Quoted: 61 Post(s)
Liked: 9
It goes without saying that a grey screen will have a lower Ambient Light Reflectance Value (ALRV) than a white screen. What I have been saying, is that a lower ALRV does not nesessarily indicate a "better" ambient light rejection capability.
For example, the Elunevision Perlux-Silver screen has better ambient light rejection than the Cinema Gray screen, in spite of a higher ALRV (0.78 vs. 0.67). What matters is the ratio between the projected image and the ambient light.
Reply Screens
