Perforated pull down???? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-23-2001, 08:05 AM - Thread Starter
DinoT's Avatar
Quoted: 30 Post(s)
Does anyone know where and if such a beast exists? I am looking for a temporary cheap screen. I will use it for a year or so until my new house is built and then I will get a really nice screen. I am looking for an 80x60 pull down. I found that Da-Lite has the Audio Vision available only on their electric or perm-wall. The electric is a mere $1500, while the perm wall is $525. I was pretty bummed since the Da-Lite hi power in a pull down is only $200 and change.
Dino
Dino
DinoT is offline
post #2 of 4 Old 07-23-2001, 01:32 PM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
Perforated screens stretch when pulled. That's why you don't see pull down models. I am not aware of anyone who makes one. Also those types of screens cost a lot more. I doubt you will find a low cost way to obtain a perforated screen.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #3 of 4 Old 07-23-2001, 04:28 PM - Thread Starter
DinoT's Avatar
Quoted: 30 Post(s)
Bulldogger,
Thanks for the reply. So far I have found that my only possible solution would be to use something called perm-wall, or something like that. It is supposed to be removable but costs $525. Ouch. I might try to rig something up where I can move my center channel forward.
Dino www.dinotheo.com
Dino
DinoT is offline
post #4 of 4 Old 07-23-2001, 05:02 PM
darth maul's Avatar
If you want to build your own screen that is perforated you can try here: http://www.grant-ent.com/dalite/wscreens19.htm Its $8 per sq. ft. for the matte white audio vision, $270 would be the price of the material in a size of 60"x80", and making your own frame will cost under $30, which brings ya to $300. Better then the $525 I guess.
darth maul is offline
Closed Thread Screens
