center channel mounting? - AVS Forum | Home Theater Discussions And Reviews
Old 07-23-2001, 07:45 AM - Thread Starter
kenh's Avatar
I have a pair of martin logan SL3's and a Cinema center the screen is a 52 x 92 Stewart permanent mount screen, I was wondering whether there would be any advantage of mounting the center channel above the screen instead of below it, any ideas or recommendations on this. thanks.
kenh is offline
Old 07-23-2001, 12:29 PM
Bulldogger's Avatar
Quoted: 205 Post(s)
Liked: 46
Are you wall mounting the center channel? I'd try both positions and decide by which location sounds best. Every set-up, I've seen so far has place the center below the screen.
Never become so involved with something that it blinds you.
Bulldogger is offline
Old 07-23-2001, 01:44 PM
yogaman's Avatar
Once upon a time I saw a post in which someone suggested one above and one below, balanced to give an image of being behind the screen.
I've also heard someone else report that they weren't satisfied with the image that they got with this technique. If you try this, let us know your impressions.
-yogaman
yogaman is offline
Old 07-23-2001, 04:54 PM
kevinu's Avatar
Ken,
I previously had a Martin Logan Logos center. I tried it in both locations and prefered it wall mounted above the screen angled down slightly.
My main speakers were the Infinity IRS Beta's, which had a high sound stage like your SL3's. Hope this helps.
Kevin
kevinu is offline
