Nec HT150 and choosing Screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-09-2001, 09:46 AM - Thread Starter
jsmin's Avatar
Thinking about getting the NEC 150 DLP projector and need some help figuring out screen type and size. The rooms dimensions are 15.8' x 14.5'. Projector will be mounted and back of room on ceiling. Room can be made very dark. Will be watching DVD's and sat. programs mostly. Sizes and why would be great.
Thanks in advance,
Jim
jsmin is offline
post #2 of 6 Old 07-12-2001, 04:43 PM
bhadsell's Avatar
A few more variables will help.
How far back will you be seated while viewing?
Are you considering motorized or fixed position?
Bob Hadsell
Home Theatre Sales Manager
DRAPER, Inc.
Bob Hadsell
DRAPER, Inc.
bhadsell is offline
post #3 of 6 Old 07-13-2001, 08:33 AM - Thread Starter
jsmin's Avatar
Be sitting around 10-12' back and fixed screen would be preferred.
Jim
jsmin is offline
post #4 of 6 Old 07-18-2001, 11:35 AM
Huckster's Avatar
Are you talking about the NEC LT150? If so, try this link. http://www.avsforum.com/ubb/smile.gif
EDIT: Sorry, this was a bit terse. The LT150 is a fixed lens (no zoom) device so the distance you mount it away from the screen COMPLETELY determines the image size.
Huck
[This message has been edited by Huckster (edited 07-18-2001).]
Huck
Huckster is offline
post #5 of 6 Old 07-22-2001, 03:43 PM
cmd1997's Avatar
Which surface will be the best?
MAT OR High Contrast for DVDs & Satellite.
cmd1997 is offline
post #6 of 6 Old 07-24-2001, 08:02 AM
Jonmx's Avatar
I think you would want to consider a screen with some gain to it, as the LT150 is not a bright projector. The thing to watch though is high gain screens are very directional and the screen material usually requires that the source comes from roughly the same direction as the viewers, so a ceiling mount situation will not work well in that case.
Jonmx is offline
Closed Thread Screens
