New be need help with screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-24-2001, 07:41 AM - Thread Starter
programmergeek's Avatar
I bought a used projector that I am putting in a room I built the sizes are below and the layout.
http://www.programmergeek.com/Pics/Basement2/index.htm
Is this the right size screen for the room or is it to big? I would perfer a roll up type, any sugestions on brands/places to buy. I plan to replace the projector in a year or two so I am more worried about room fit.
http://www.programmergeek.com/Pics/Basement2/layout.gif<FONT COLOR="Blue">Text</FONT c>
[This message has been edited by programmergeek (edited 07-24-2001).]
Jason
Note: Any posts are of my personal opinions and not to reflect upon any business.
Jason@programmergeek.com
908 578-6466
programmergeek is offline
post #2 of 2 Old 07-24-2001, 06:18 PM
Angeli662's Avatar
Your question would be better answerd if you discrib more about your projector then the room for exemple:
Lummenes, resolution throw distence etc... it is a small screen and you might be able to get a larger 16.9 Rick
also try to contact Stweart Screens or Da-lite.
Angeli662 is offline
Closed Thread Screens
