Which aspect ratio screen to buy? - AVS | Home Theater Discussions And Reviews
Screens > Which aspect ratio screen to buy?
bpape's Avatar bpape 05:31 AM 07-31-2001
Looking for opinions on which aspect ratio screen to buy for XG135. See link below.
Thanks in advance.
http://www.avsforum.com/ubb/Forum2/HTML/008488.html
THE answer is 42.
DMan's Avatar DMan 12:52 PM 07-31-2001
Use a 16:9 screen with your NEC XG135LC. This way the highest resolution sources (HDTV and 1.78 & 1.85 DVDs) will have the most real estate to display their image. And the slightly lower rez 2.35 DVDs and considerably lower rez 4:3 NTSC sources will be slightly smaller on the 16:9 screen.
Enjoy,
DMan
The Academy Home Theater
Art Sonneborn's Avatar Art Sonneborn 07:52 PM 07-31-2001
I believe that there is much wisdom in the compromised 1.78:1 aspect ratio since it really seems to allow the greatest use of screen for the maximum number of movies. And it also is the HD ratio.
Up
Mobile  Desktop
