Status
Not open for further replies.
Stewart Horizontal Masked Screen
352 views 2 replies 2 participants last post by  Nick Beecham
#1 ·
I'm thinking about taking the plunge and going for one of these.
Does anyone know whether it is possible for the masks to cover the entire screen, so as to protect it when not in use?
Many thanks in advance
Nick
#2 ·
I helped a friend install a Stewart roll-up horizontally masked screen last weekend. When fully extended, the standard mask covered almost half of the screen. I assume you're going to use a fixed wall mount (otherwise protecting the screen would not be an issue).
As I under it, Stewart can build screens to almost any specification. I would ask them...
Randy
G20/CI/GrayHawk
Status
You have insufficient privileges to reply here.
