Other options than da-lite 100" - AVS Forum
Old 08-05-2001, 08:11 PM - Thread Starter
AVS Club Gold
programmergeek's Avatar
I like the da-lite 80"X60" model B video Spectra 1.5 gain pull down screen. The thing that is most appealing is that it can be cleaned. I got samples and I did notice the "sparkles", I not sure if this will bug me so I want to investiagate other options. What other brands / modles should I look at?
Jason
Note: Any posts are of my personal opinions and not to reflect upon any business.
Jason@programmergeek.com
908 578-6466
programmergeek is offline
Old 08-06-2001, 08:33 AM - Thread Starter
AVS Club Gold
I contacted Draper and they told me that flat white with a 1.0 gain is the standard. Is this true? Do people now veer away from the screens with gain? I am confused I got Da-Lite samples and the one that I thiught looked the best had a gain of 1.5, it seemed to bring more detail out. Should I get a flat white I am using a sharp notevision xg-nv2u 700 ANSI.
Jason
908 578-6466
Old 08-06-2001, 09:54 AM
KFung's Avatar
Your screen is not too large so I would recommend checking out the Da-Lite HC Da-Mat or Stewart Greyhawk. Both are grey screens that will dramatically improve your black level. The HC Da-Mat may be a little too dark for you application, but the Stewart screen will be quite pricey relative to what you paid for your projector (on the other hand it has an optical coating that will slightly enhance you contrast). You should definitely evaluate samples of both.
Kam Fung
KFung is offline
