GrayHawk gain question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-07-2001, 11:45 AM - Thread Starter
Ben
Ben's Avatar
My GrayHawk screen should be in the truck on its way to VA...I'm getting excited to get it. http://www.avsforum.com/ubb/smile.gif
One question, I thought the GrayHawk gain was .85, but the Stewart web site lists the gain as .95. Is that right?
Ben
[This message has been edited by Ben (edited 03-07-2001).]
Ben is offline
post #2 of 6 Old 03-07-2001, 02:04 PM
Bulldogger's Avatar
Quoted: 191 Post(s)
Liked: 44
The gain for the regular screen is .85. They increased the gain to .95 for the perforated sceen because you lose some gain due to the holes. If you have a micro-perf then the gain is going to be higher. If you do not it will be .85
Never become so involved with something that it blinds you.
Bulldogger is offline
post #3 of 6 Old 03-25-2001, 03:10 PM
OpusX's Avatar
Ben,
Can you please email me you findings when you get your screen set up? I live in Sterling also and I am debating on which screen to get. Let me know what you think.
TIA
OpusX is offline
post #4 of 6 Old 08-04-2001, 05:17 AM
Cain's Avatar
Quoted: 321 Post(s)
Liked: 173
OK, if I am planning to use a Grayhawk, and a perforated screen, do I need to deduct any brightness for the perforations, or does .95 consider that already??
<scratching head> ??
-- Cain
Cain is offline
post #5 of 6 Old 08-04-2001, 10:06 PM
REW
REW's Avatar
Usual perf loss is said to be 10%.Thus perceived brightness is same(.85 approx for both.)
Ron
"Your priorities will be different-its the weighting that counts!"
Ron
"Your priorities will be different-its the weighting that counts!-only if its done by FET!"
REW is offline
post #6 of 6 Old 08-07-2001, 12:40 PM
Jason Turk's Avatar
The rated gain of the non-perfed screen is indeed .85 for the Grayhawk. However, in testing they have found that it is actually closer to .90+. Stewart quotes conservative gains so that if it happens to be more you will get a bonus. Some other companies quote higher than true gains for their screens to hype them up more. Another reason Stewart is the best!
Jason Turk
AV Science, Inc.
http://www.avscience.com
716-454-1460 ext.204
Jason@avscience.com
Jason Turk is offline
Closed Thread Screens
