Glass beaded Dalite Model B any good for less than 600 lumens LCD projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-09-2001, 03:20 PM - Thread Starter
Huey's Avatar
It's cheaper than hi-power and have 2.5 gain. What do you all think about this type of material for LCD projector? Thanks for replying.
Huey ;-]
Huey ;-]
Huey is offline
post #2 of 6 Old 08-09-2001, 05:45 PM
Jon_Mitchell's Avatar
I have the same projector, the cx1, and am interested in whether the glass beaded would work better than the matte white for a model C Da-lite
Jon_Mitchell is offline
post #3 of 6 Old 08-09-2001, 06:32 PM
KFung's Avatar
What size of screen are you looking at?
Will you projector be mounted on the ceiling or on a table?
Kam Fung
KFung is offline
post #4 of 6 Old 08-10-2001, 07:50 AM
Blake Brubaker - Da-Lite's Avatar
Huey and Jon,
For a Home Theater application, traditional glass beaded surfaces are not a good choice. The beads are too large and mixed with a fixed pixel device (LCD or DLP Projectors) the image will appear grainy from the close distance you will be viewing a screen in the Home Theater setting. Also if your projector is ceiling mounted Glass Beaded is not the screen of choice because it is retro-reflective which means that it directs the light back from where it came. What you should consider instead is a 1.5 gain screen like our Video Spectra 1.5. It gets it's gain from a different type of reflective material and is not retro-reflective.
Blake
Blake
Blake Brubaker, CTS
Vice President of Sales
Da-Lite Screen Company, Inc.
Blake Brubaker - Da-Lite is offline
post #5 of 6 Old 08-10-2001, 07:53 AM - Thread Starter
Huey's Avatar
I have a DIY matte white duck cloth (gain of 0.9 to 1) now with my Sony VPL-CX1 on a shelf 2 feet above my head against the back wall. Its image is great but I want to leave more lights on for wife to read a book so I'm trying to find a higher gain screen. With the lights on enough to read comfortably, currently the night scenes are dim but daytime scenes are OK. So I thought a higher gain screen may improve my ambient light level and image brightness. The size I wanted was 69X92 for $160 at www.cousinsvideo.com model B Dalite glass-beaded, gain of 2.5. Hi power probably would be better but is $100 more ($262). Thanks for replying.
Huey ;-]
Huey ;-]
Huey is offline
post #6 of 6 Old 08-11-2001, 09:24 PM
Noah's Avatar
Any thoughts on how the "large-grained" glass bead Model B might fare with a low output CRT projector? I have a Sony VPH-1031Q (500 lumens I think) that I've been using with a homemade screen and I'm thinking that a commercial high gain screen might be a good upgrade.
Noah is offline
Closed Thread Screens
