Help Da-Lite new screen material for my tensioned Electrorol how to install - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-09-2001, 09:09 PM - Thread Starter
Rickd's Avatar
I received a new roller and slat with Cinevision one material on it to replace my old high gain Pearlescence (the 2.0 gain stuff) and I need some advice on how to install it as I only received half the instructions.
Firstly the new slat that sits at the bottom... is this installed prior to installing the new roller and material into the case or done once the roller and material is in the case.
The tensioning wires also have to be tied on too.
Rick
No matter where you go there you are!
Rickd is offline
post #2 of 2 Old 08-13-2001, 04:22 PM - Thread Starter
Rickd's Avatar
Figured this out and installed it must say that the Cinevision material makes a huge difference from the old Pearlescence even the lose in gain seems minimial. No more hot spoting and no more sparkles and the colour is so much more vibrant and uniform. Worth the $1000 for the new roller and material.
R.
Rickd is offline
Closed Thread Screens
