first coat of paint? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-16-2001, 04:00 PM - Thread Starter
Chris Carollo's Avatar
I've got my frame about done, and I'll be picking up some fabric this weekend, and I was wondering what people do for the first coat of paint on their screens. Do people typically apply multiple coats? If so, is there a type of paint that will "prime" the surface for the final paint?
Chris Carollo is offline
post #2 of 2 Old 08-17-2001, 05:55 PM
Gary McCoy's Avatar
Quoted: 101 Post(s)
Liked: 97
I started with a bedsheet because I wanted a screen taller than the 54" blackout fabric most people are using. Therefore after washing and drying and ironing the sheet I used latex primer/sealer as a first coat. Use half the normal soap, no fabric softener, no starch, no bleach, no enzymes, and rinse twice in clear water. Con your wife into the laundry part if you dare!
I believe if you are using the blackout fabric the smooth vinyl side will accept the finish paint with no primer needed.
Gary
[This message has been edited by Gary McCoy (edited 08-17-2001).]
Gary McCoy
The United States Constitution ©1791. All Rights Reserved.
Gary McCoy is offline
Closed Thread Screens
