GrayHawk vs. ND Filter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-17-2001, 11:39 AM - Thread Starter
honcho's Avatar
I'm looking at getting a GrayHawk for a bright LCD projector (1500 to 2000 lumens, haven't picked the projector yet). My HT/living room won't let me have great light control (ok, it's my wife and budget).
Can I get the benefits of the GrayHawk using a neutral density filter over the projector lens and a 1.3 gain screen? I know that I could have a problem with ambient light that the GrayHawk would be better at solving. But some day, I might be able to take care of the ambient light issue.
Honcho
Honcho
honcho is offline
post #2 of 5 Old 08-17-2001, 05:51 PM
KFung's Avatar
No, I'm afraid an ND filter will not give you the benefits of a Greyhawk. All it really does is cut your brightness, which you don't really need to do (after all you're paying for those lumens!). The Greyhawk also cuts your screen brightness a bit, but it has other benefits. Even in a light controlled room without ambient light, the Greyhawk will still give you more than an ND filter. The Greyscreen increases your dynamic contrast ratio because it absorbs some of the light reflected back from your room (unless you have black walls, ceiling) and the optical coating rejects light reflected from the ceiling and floor. This also serves to increase your colour saturation because you don't have as much light from the room to wash out bright colours.
Kam Fung
KFung is offline
post #3 of 5 Old 08-17-2001, 07:12 PM - Thread Starter
honcho's Avatar
Thanks Kam. What you said makes lots of sense.
As a related question, I'm slightly concerned that the GrayHawk will make whites look dull (I hate gray teeth http://www.avsforum.com/ubb/biggrin.gif). Does this happen? Is it quite noticeable?
Honcho
Honcho
honcho is offline
post #4 of 5 Old 08-20-2001, 05:07 PM
KFung's Avatar
Honcho,
Actually the screen won't appear grey unless you have a "white" reference next to it (e.g. a piece of paper). Our brains are kind of tricky, if you see something that your brain thinks should be "white" it appears white to you. It makes sense if you consider that paper looks white under all different levels of light. It's all relative!
Kam Fung
KFung is offline
post #5 of 5 Old 08-21-2001, 12:08 AM
REW
REW's Avatar
Most people will be happy as Kam points out.I can only speak for myself after direct A/B comparisons.Dont compare-its revealing.Once you know its there (AAK!)
http://www.avsforum.com/ubb/smile.gifA far greater factor is the "limp" look of low gain screens.
"The Shadow(KODAK)knows!"
Ron
"Your priorities will be different-its the weighting that counts!"
Ron
"Your priorities will be different-its the weighting that counts!-only if its done by FET!"
REW is offline
Closed Thread Screens
