Help!!! How to control a stewart screen with a Philips Pronto! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-20-2001, 01:23 PM - Thread Starter
SleeplessInSeattle's Avatar
I have a Stewart ElectircMask Screen, it has two triggers
to control the up & down of the screen and the mask.
but how to use the "Pronto" to control the two triggers?
What tools should I buy?
Thanks very very much!
www.MyAV.com.tw
-The Biggest Chinese AV Forum in Taiwan
SleeplessInSeattle is offline
post #2 of 5 Old 08-20-2001, 05:11 PM
KFung's Avatar
Hmmm,
It should be possible, I know Stewart has an IR control box. You should be able to use that and train your Pronto to control it.
Kam Fung
KFung is offline
post #3 of 5 Old 08-20-2001, 06:29 PM
Jason Turk's Avatar
Which triggers do you have? You need the DIR120 which is a dual channel IR controller. If you have that then you should be able to teach the remote the proper codes.
Jason Turk
AV Science, Inc.
http://www.avscience.com
716-454-1460 ext.204
Jason@avscience.com
Jason Turk is offline
post #4 of 5 Old 08-22-2001, 06:00 PM
pamajmudar's Avatar
If you have a non-masked screen, (electric, with IR remote), do you need any special equipment to be able to control it with the Pronto?
Parag
pamajmudar is offline
post #5 of 5 Old 08-22-2001, 06:03 PM
Jason Turk's Avatar
If you have a basic electric screen, then there is only one motor. In that case, all you need is the basic IRR control from Stewart. If you have an Electriscreen Electrimask, there are 2 motors, and you would need the 2 channel IR system. Hope that helps!
Jason Turk
AV Science, Inc.
Jason@avscience.com
Closed Thread Screens
