Dalite Glass bead or High Power for LT-150? - AVS Forum | Home Theater Discussions And Reviews
Old 08-22-2001, 07:43 PM - Thread Starter
Averian's Avatar
Is the $100+ difference worth it for Dalite Model B High Power over Glass Bead? What are the tradeoffs? (or should I even consider Video Specra 1.5?)
Averian is offline
Old 08-23-2001, 01:36 PM
thxave's Avatar
Hello, I have had both screens.
The regular Da-lite glass beaded screen is not very good for video. It is much to grainy. You will not be happy with it(IMO). The High Power Da-lite screen is glass beaded but uses much smaller beads. It also has a protective coating protecting the beads. If you use mattes or roll the screen up a lot the glass beads on the normal glass beaded screen will wear off quite quickly.
Avery
My HT Pics http://members.aol.com/thxavery/
thxave is offline
