Blackout material - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-21-2001, 02:22 PM - Thread Starter
AndyN's Avatar
Quoted: 23 Post(s)
Quick question for DIYer's. I found the blackout material at Calico Corners in the Bay Area. Problem is they said that it came it white and off white. They guy showed me the WHITE but it looked off whitish (brownish tinge to it). Problem is they didn't have the other color to compare. Home depot doesn't have any so I'm stuck with these guys.
IS the material supposed to not look "pure" white? Also is pure white or off white better for CRT's (8inchers).
Thanks guys, this forum is awesome.
Andy
AndyN is offline
post #2 of 8 Old 08-21-2001, 07:23 PM
dhanson's Avatar
The stuff I bought was white on one side, and off-white on the other.
dhanson is offline
post #3 of 8 Old 08-22-2001, 06:47 AM
darth maul's Avatar
I had to vist JoAnn Fabrics and Hancock Fabrics several times before I found the right bolt of fabric that looked the most white to me. Several samples looked like they had a blueish tint to them. Just vist the all the fabric stores you can, and make note of what kind of lighting you are viewing it under.
darth maul is offline
post #4 of 8 Old 08-22-2001, 08:42 AM
Brian Hampton's Avatar
Quoted: 584 Post(s)
Liked: 312
Hello,
I'm in the bay area and I used the fabric from Calico Corners. However, I used Jo Ann's blackout fabric for control of ambient light and my experience with each seems to indicate the stuff at Jo Ann's is "the" stuff to use. It's more durable, creases come out sooner, It's just better. By the way, when I bought my fabric I tried to roll it up but it still got creases (fold lines) in it so I suggest you take a mailing tube or something you can roll the fabric up with. This may not be as much of a problem with the stuff from Jo Anns though.
Good Luck,
Brian
p.s There's plenty of Jo Ann's in the bay area so you're not stuck with Calico Corners. If you don't have a car though and need a lift to Jo Ann's then let me know.
[This message has been edited by Brian Hampton (edited 08-22-2001).]
Brian Hampton is offline
post #5 of 8 Old 08-22-2001, 11:33 AM - Thread Starter
AndyN's Avatar
Quoted: 23 Post(s)
Originally posted by Brian Hampton:
Hello,
Good Luck,
Brian
Brian,
Thanks for the info. Do you mind me asking which Jo Ann's you went to? I called one place and the very young and busy cashier told me they didn't have any. Thanks again.
BTW, was your Calico Corners fabric off white (tan-ish) or bright white?
Thanks again,
andy
AndyN is offline
post #6 of 8 Old 08-22-2001, 10:52 PM
albert105's Avatar
Joanne's "blackout" fabric. SKU 2117232 @ $5.99/yd. in San Diego.
albert105 is offline
post #7 of 8 Old 08-23-2001, 10:53 AM
Huey's Avatar
I bought some blackout too but has a few wrinkles. Can I iron this out on low heat settings on a cloth side? Will the vinyl melt on the otherside? Can I use steam? I know stretching will help but I'd like to iron the piece before stretching on frame if possible. Thanks for any reply. I got mine from my local, small-town fabric store: Fabric and Drapery Mart (937) 584-2771 (9A to 4P Eastern Time). I bought it for $4.50 a yard on a 54" wide bolt. I bought 3 yards for an 8 foot wide screen (16:9 ration will be 96"X54"). It's bright white on cloth side and less white on the vinyl side. It's is comparable to my 1.1 gain Bretford manual pull-down screen (70"X70"). A bright 6V flashlight can't shine through on otherside (therefore called blackout).
Huey ;-]
Huey ;-]
Huey is offline
post #8 of 8 Old 08-25-2001, 04:27 PM
Bill Jones's Avatar
I just stretched mine over a 45x80x1/4" board(pegboard material without the holes) and stapled it to the back. I was able to stretch all of the wrinkles out and mine had sat folded overnight. I ended up putting the vinyl side out and it seems to be working very well. Mine was pure white on both sides. I then covered 2x2"s with velvet for the boarder. Good luck.
Bill
Bill Jones is offline
Closed Thread Screens
