Da-Lite or Stewart - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-23-2001, 07:16 AM - Thread Starter
FASTLS's Avatar
Which screen would be better for use with a Sanyo PVL-60,
the Stewart Greyhawk or the Da-lite Cinema Contour with the High Contrast Da-Mat finish. Would the gain of .8 of the Da-lite versus the .95 of the Grayhawk be a big concern?
Also, Da-Lite state the viewing angle of the Da-Mat is only 40 degrees where the Greyhawk is 160. All help would be appreciated.
FASTLS
FASTLS is offline
post #2 of 9 Old 08-24-2001, 12:55 AM
I'mListening's Avatar
FASTLS:
I can hear the can of worms opening now! You will probably get a diversity of replies to this topic. However. The best thing is to CHOOSE for yourself. Since imagery is quite subjective to an individuals taste, only you will be able to decide which IS best for your set-up.
You can email both STEWART and DA-LITE for samples of each screen material they manufacture. This is what I ended up doing, and one by one narrowed the selections down to two out of about fifteen samples. I narrowed my selections to the STEWART GreyHawk and DA-LITE'S High Contrast Da-Mat.
Then after about a week or two of comparisons I picked the DA-LITE HC Da-Mat Tensioned Electrol-Cosmopolitan. I personally thought it enhanced the contrast better than the GreyHawk. The price was much more affordable for me than the Stewart, however the Stewart material was a bit heavy dutier in thickness than the Da-Lite...but this really was not an issue for me, as I was more concerned with the projected image. I use the screen with the Sony 10HT (600/1000 lumens) and am 100% satisfied with my selection. Best thing is...I read everyones reviews and opinions...then checked out the samples myself...and then made an informed decision. I have no "buyers remorse" wondering "What If" I had bought another screen, since I checked them all out first.
Darren from Kansas City
Thanks for reading!
Darren Mortensen
Cinema At Home: A/V Interior Design
I'mListening is offline
post #3 of 9 Old 08-24-2001, 06:58 AM
DaveN's Avatar
Quoted: 68 Post(s)
What size are the samples that they send? Also how did you do your comparison? I already have a screen but I might be interested in changing if the picture is really improved.
Dave
DaveN is offline
post #4 of 9 Old 08-24-2001, 08:58 AM
cin
cin's Avatar
Hi Dave:
I work for Stewart's Marketing Dept and may be able to help.
We have a variety of sample sizes we can send you. Please email me your address and we will send you the requested material.
Below is a good guideline in reviewing screen samples.
HELPFUL HINTS FOR EVALUATING SCREEN SAMPLES
Tape screen sample(s) to a flat vertical surface, such as a wall. Ordinary masking tape works well. Screen samples should be perfectly flat with no wrinkles.
It is much more efficient to study and evaluate still images rather than chasing an image in motion. From a video source, select an appropriate image and freeze the frame. Be sure to select a variety of material, such as a bright daytime image with deep shadows. Also, project images with dark screens, such as a night shot, to evaluate shadow detailing and black levels.
Evaluate the image quality from an appropriate viewing distance. Both the projector and screen will not look true at very close viewing.
Evaluate the screen performance from different seats and viewing angles. Try the seat which is the least perpendicular to the screen's centerline.
Introduce ambient light into the room. Try to duplicate actual conditions that you wish to view your system.
Position your projector in the same vertical orientation that will be permanently used. Some screens are gain sensitive to a floor or ceiling mount projector.
Try out these steps with your samples. It may help you in your decision. As Darren said read old posts, study your options, and make an educated decision.
Cindy
[This message has been edited by cin (edited 08-24-2001).]
cin is offline
post #5 of 9 Old 08-24-2001, 09:52 AM
finalwish's Avatar
Cin,
What is your email address?
finalwish is offline
post #6 of 9 Old 08-25-2001, 12:09 PM
nerbe's Avatar
Hi Cin,
Please check your private messages here.
Neil
nerbe is offline
post #7 of 9 Old 08-26-2001, 06:06 AM
FASTLS: Cindy's post is an excellent example of how to properly distinguish between samples! I must say that STEWARTS samples were nicely arranged 8x10 sheets (I think) and Da-Lites were quite abit smaller in comparison.
Thanks for reading!
Darren Mortensen
post #8 of 9 Old 08-28-2001, 08:08 PM
finalwish's Avatar
Folks,
Do you know who to contact to get a quick response to
get samples? I tried leaving pm for Cin, but not sure
if she read it or not... I'm thinking of going through
another route to see if I can get samples quicker. Any suggestions?
post #9 of 9 Old 08-29-2001, 09:20 AM
cin
cin's Avatar
I must apologize, I have not logged on to the forum the last few mornings. We are in the Cedia preparation mode. If you need me to immediately respond please email me directly at cindy@stewartfilm.com.
Finalwish, I had your samples sent out on Monday. They are 8 1/2 x 11 sheets. Hope they help.
Cindy
[This message has been edited by cin (edited 08-29-2001).]
cin is offline
Closed Thread Screens
