Screen Size? 1.78:1 or 1.85:1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-23-2001, 07:16 AM - Thread Starter
FASTLS's Avatar
If you were putting a fixed 16:9 screen, which aspect ratio size is best? 1.78:1 or 1.85:1? What do most people install.
FASTLS
FASTLS is offline
post #2 of 4 Old 08-23-2001, 10:29 PM
Banger's Avatar
Hi,
It really depends what you plan on watching most. If you want to see "all" of the movie, go for 1.85. But then you will have some small black bars when you watch 16:9 material. Considering that feature films are shot 1.85:1 or 2.40:1, I would go for 1.85
Banger is offline
post #3 of 4 Old 08-25-2001, 07:08 PM
Art Sonneborn's Avatar
Quoted: 348 Post(s)
Liked: 471
I use a 1.78:1 and have been pleased with it. My understanding is that this ratio was selected to give the best compromise between various film ratios and also the 1.33:1 of standard TV as well as the 1.37:1 ratio of pre 1953 films. If you use a 1.78:1 screen you are also using the HD format. Also the 1.85:1 films fill the screen anyway if you have approximately 2% overscan.
Art Sonneborn is online now
post #4 of 4 Old 08-29-2001, 12:11 PM
Gertjan's Avatar
Hi FASTLS,
Here's an excellent article explaining aspect ratios, and where the 16:9 came from.
http://www.hometheatervillage.com/vi...ect_ratios.pdf
Basically 16:9 (1.78:1) is the ideal ratio to display other formats on in a uniform way.
"He who asks feels dumb for a few minutes, but he who does not ask remains dumb forever."
Gertjan is offline
Closed Thread Screens
