Worth the upgrade? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-07-2001, 02:22 PM - Thread Starter
Andrew Low's Avatar
If you have an existing screen that you can't spot any flaws in, I would stick with what you have.
You might gain some "punchiness" to the image (brighter, better contrast) by changing screens -- but not enough to justify the cost (IMHO).
Better to invest in having a good (recommended) ISF tech come and give the system a once over and set your gray scale. Sorry, I have no recommendations for ISF in your area.
Roo
Andrew Low is offline
post #2 of 3 Old 09-07-2001, 09:31 PM
ghoniba's Avatar
Hi Gang
I have a Sony 1271Q and I use it with a plain old screen with a gain reading of 1.0 (I think it's called a
'Brentwood' or something like that) as recommended by the installer when the projector was installed. (
for some reason the installer didn't seem all that high on screens with gain) It seems to work well and I
can't say that I'm unhappy with it.
I am just wondering, I know that the Stewart screens are very well respected and some of the Home
Theater mags use them as a reference when testing projectors.
Can anyone please tell me if I would see much of a difference going from my present screen to a
Stewart Studiotek with a gain of 1.2 or 1.3?
Thank you, Glenn
ghoniba is offline
post #3 of 3 Old 09-10-2001, 04:50 AM
ghoniba's Avatar
Andrew
Thank you for the honest reply.
Glenn
ghoniba is offline
Closed Thread Screens
