HELP!!! DaLite perm wall question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-14-2001, 05:26 PM - Thread Starter
Super Moderator
Bob Sorel's Avatar
Quoted: 73 Post(s)
Liked: 126
I have asked this very same question before, and no one wants to answer it:
Why would any manufacturer make a screen translucent when it can be made opaque?
Unless there is some reason that the picture quality is improved with translucent screens, it just seems ridiculous to me also. With the price that these companies charge for their screens, you would think that they would manufacture them all with opaque material.
Does anyone know?
STOP DVI/HDCP/5C/DFAST!
Bob Sorel is offline
post #2 of 4 Old 09-14-2001, 07:48 PM
DaveN's Avatar
Quoted: 71 Post(s)
The picture is most definitely not improved by a translucent screen. For maximum picture quality and contrast the wall behind the screen and 2 feet on every side should be black. I glued black velveteen material on my front wall and it turned out very well. The whole wall appears to fade into the floor.
Bob,
You are correct. I can't answer you eitherhttp://www.avsforum.com/ubb/wink.gif.
Dave
DaveN is offline
post #3 of 4 Old 09-14-2001, 10:46 PM
programmergeek's Avatar
I got a DaLite DaMat screen and frame. The screen is white with no backing it appears light will go through the screen somewhat. This screen is going to be placing agents a whit wall. Will I have wash out from light trying to come back through it? I understand you can order a black back on them but that option was not given to me when I ordered so I guess I got stuck with the wrong screen. Should I put a piece of black cloth behind it? Or is this not a problem. I can’t believe da-lite would make a screen that mounts to a wall that light travels through. It just seems stupid.
Jason
Note: Any posts are of my personal opinions and not to reflect upon any business.
Jason@programmergeek.com
908 578-6466
programmergeek is offline
post #4 of 4 Old 09-15-2001, 11:24 AM
Signal's Avatar
See Stacy Spears' comments in this thread: http://www.avsforum.com/ubb/Forum9/HTML/000161.html#4
It's most disappointing. I shall have to go all-out on some modifications.
Signal is offline
Closed Thread Screens
