Best paint for Hi gain on blackout fabric w/ LT150 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-21-2001, 06:36 AM - Thread Starter
hardwired's Avatar
Quoted: 12 Post(s)
I am currently using the white glossy Tile Board from Home Depot and like the results but would like to try building a DIY screen from blackout fabric from JoAnns that I already have.
I compared the natural blackout fabric to the Tile Board and was surprised that the Tile Board was so much better - brighter due to the higher gain of the Tileboard finish. So I am looking for a paint with high gain that will be hopefully somewhat close to the results of the Tile Board.
I have seen some of you mention blackout fabric from a place called Hancock. How does the color (white or greyish) and gain compare between the Hancock and JoAnn fabric. Am I just better off using the Hancock natural or painting what I have.
Also, what is the best method for applying the paint and how much do I need to cover the (quart or gallon).
Hardwired
TI Purepath Digital:
An audio revolution from the source to the ear...found in $99 DVD receivers to audiophile-grade $10,000 audio systems.
hardwired is offline
Closed Thread Screens
