Give me what I want - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-27-2001, 02:54 PM - Thread Starter
AfroCreame's Avatar
I'll be using a LT150, ceiling mounted, etc. The screen that I've been recommended to is to a high powered (2.8 Gain) screen. Will have problems with this in regards to a ceiling mounted LT150? If not where can I order this:
Da-Lite Cinema Contour 45x80 High Power 2.8 Gain
If you have any information on where I can order this exact setup, price, etc. it would be greatly appreciated. Most places that I've found on the net (2-3) offer this but only in matte finish. If you don't think this screen wouldn't work well what do you recommend. Thanks for any inputs!
Fro
AfroCreame is offline
post #2 of 3 Old 09-27-2001, 03:36 PM
TGroom's Avatar
You should really check out this thread. http://www.avsforum.com/ubb/Forum9/HTML/001345.html
Tim
TGroom is offline
post #3 of 3 Old 10-01-2001, 11:34 AM
Jason Turk's Avatar
Dalite does indeed make the Cinema Contour with the High Power material. I'm not sure why the places you are finding don't carry it. Drop me an email and I can get you some idea on pricing for it.
Jason Turk
AV Science, Inc.
http://www.avscience.com
716-454-1460 ext.204
Jason@avscience.com
Jason Turk is offline
Closed Thread Screens
