Masking material? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-03-2001, 09:30 PM - Thread Starter
GaryWW's Avatar
I have some heavy DuveTyne material left over after covering (the inside of) my RPTV. Would this be a good material for masking for my FP screen?
GaryWW is offline
post #2 of 3 Old 10-03-2001, 10:41 PM
KFung's Avatar
It should work pretty well, I'm not too familiar with DuveTyne, but it's been widely used to line the inside of RPTV's by DIY'ers (as you've found out). If it is suitable for that, it should also work for FPTV masking.
Kam Fung
KFung is offline
post #3 of 3 Old 10-04-2001, 09:14 PM - Thread Starter
GaryWW's Avatar
Kam,
Thanks for your input. I guess its worth a try.
GaryWW is offline
Closed Thread Screens
