Is it "wide" or "diagonal"? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-05-2001, 08:44 PM - Thread Starter
tim55's Avatar
I know 4x3 screens are measured diagonally, but are 16x9?
Thanks in advance
tim55 is offline
post #2 of 6 Old 10-05-2001, 09:25 PM
carlos_r's Avatar
all screens are measured diagonally
unless otherwise specified
carlos_r
ecp4100(07ms)
diy 80x45 (16x9 painted fabric screen)
HTPC/Radeon 64ddr/ATI4.1 dvd
carlos_r is offline
post #3 of 6 Old 10-06-2001, 08:13 AM
Vern Dias's Avatar
I think that should read:
"All self contained television screens are measured diagonally unless otherwise specified".
Screens for other purposes such as FPTV, Film, Slides, etc are usually measured in a H x W configuration.
Vern
[This message has been edited by Vern Dias (edited 10-06-2001).]
Vern Dias is offline
post #4 of 6 Old 10-06-2001, 04:55 PM
John Kotches's Avatar
Vern,
You can certainly think that's how FP screens are sold, but having gone through a round of purchasing one I can tell you that diagonal measurements are what is used.
I spec'd my maximum width, and was told "For a 4:3 aspect ratio, that's an 84" diagonal".
YMMV.
Editor, PC/Home Theater Secrets of Home Theater and High Fidelity
Contributing Editor & Surround Music Reviewer Widescreen Review
Opinions are mine, not the publication I write for.
John Kotches is offline
post #5 of 6 Old 10-07-2001, 08:23 AM
Art Sonneborn's Avatar
Quoted: 238 Post(s)
Liked: 295
At least in most HT mags and on this forum ,front projection screens are given a width dimension then often the aspect ratio after that. The example is 107" wide at 16x9. Most on this forum don't use the diagonal measurement at all.
My HT
iRule rules my theater
Art Sonneborn is offline
post #6 of 6 Old 10-07-2001, 03:34 PM - Thread Starter
tim55's Avatar
Thanks for the help.
tim55 is offline
Closed Thread Screens
