SATIN & EGGSHELL PAINT MIXED - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-07-2001, 01:25 PM - Thread Starter
pcostanz's Avatar
This is similar to my last post. Has anyone tried to mix both eggshell and satin behr paint together? The satin was a bit too shiny, I'm wondering if a mix of both would work?
-Peter
-Peter
pcostanz is offline
post #2 of 7 Old 10-08-2001, 07:17 AM - Thread Starter
pcostanz's Avatar
I tried a mixture of about 70/30 EGGSHELL/SATIN. It works. I can tell you that the paint has more of a sheen than satin, but is just below the hotspot level. I'm using a DLS8 projector ceiling mounted. I'm curious what would happen if I tinted the paint with a very light grey. Anyway, it's worth looking at. The paint really provides a boost over flat paint. Definetely better.
-Peter
-Peter
pcostanz is offline
post #3 of 7 Old 10-08-2001, 01:19 PM
pcdoctor's Avatar
I have used Behr "ultra pure white" flat and Home Depot converted it to Behr "gray tropics".
It looks great!
To the naked eye it looks white but when compared with a white primer, it looks like a very light gray.
My HT
pcdoctor is offline
post #4 of 7 Old 10-08-2001, 01:56 PM - Thread Starter
pcostanz's Avatar
What projector do you have?(how many lumens) Did it lower the brightness much?
-Peter
-Peter
pcostanz is offline
post #5 of 7 Old 10-08-2001, 02:41 PM
pcdoctor's Avatar
I have a Sanyo SU07N
Lumens 700.
It didn't really lower the brightness that much because to the naked eye it's such a light gray.
QUOTE]Originally posted by pcostanz:
[/quote]
My HT
pcdoctor is offline
post #6 of 7 Old 10-08-2001, 03:52 PM
mercury's Avatar
Liked: 101
For about a 1.3 gain(crt)ultra pure white????is this correct,do we prime first,
tommy
Coming fall 2001"The Merc"
?ai=4292339987
Panasonic 65" plasma*
Denon 4520*
PSB T45* PSB B15* PSB C60*
Dual PSA XS30* Dual PSA XS15se*
Squeezbox*
Niles ZR-6 6 Source, 6 room Audio Reciever*
mercury is offline
post #7 of 7 Old 10-08-2001, 05:22 PM - Thread Starter
pcostanz's Avatar
mercury, I believe the 1.3 gain is the BEHR ULTRA PURE WHITE in and EGGSHELL finish, not flat. Flat is ~1.0 gain. I mixed a bit of satin in with eggshell, I came out good. I first tried satin by itself, but it was too shiny, especially since I used a roller which gives a bit of texture. Funny enough, it looked very similar to the Dalite 2.5 gain screen I tried, but sent back (i.e. texture & too shiny)
-Peter
-Peter
pcostanz is offline
Closed Thread Screens
