Help with screen size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-07-2001, 06:43 PM - Thread Starter
orbillius's Avatar
I am finally making a 16x9 screen for viewing HD content in the living room. My couch is 10 feet away from where the screen is going to be. I am using an LT154 projector fed by a DTC 100.
I was planning on making a 5 foot wide screen. DO any of you think that this is too big/small given the viewing distance of 10 feet? Any advise would be appreciated.
VISIT HDTVOK.COM
tulsaprojector.com
[This message has been edited by orbillius (edited 10-07-2001).]
orbillius is offline
post #2 of 6 Old 10-07-2001, 10:27 PM
JAB
JAB's Avatar
It passes the traditional wisdom of being 2x the screen width from the screen.
/jab
a moderator at the TiVo Community Forum
JAB is offline
post #3 of 6 Old 10-08-2001, 07:30 AM - Thread Starter
orbillius's Avatar
I should have thought of that. It seems small, but from that distance I think it will be very enjoyable.
VISIT HDTVOK.COM
tulsaprojector.com
post #4 of 6 Old 10-08-2001, 09:59 PM
rwhitley's Avatar
orbillius,
My personal feeling would be to go bigger, it may not be the conventional wisdom, but to use only a 5' screen would seem a shame, why not put up a sheet and see what size you are most happy with.
For me, the bigger the better, within reason.
Rick
rwhitley is offline
post #5 of 6 Old 10-09-2001, 12:27 AM
Varmint's Avatar
I have the same projector, the same viewing distance and I went with a 96"x54" screen. I am only using the middle 4:3 section of the screen at the moment and I think the size is perfect, the pixels are just visible. Besides, 55" wide screen material is readily available for about $5/yard.
-Kai
Varmint is offline
post #6 of 6 Old 10-09-2001, 10:40 PM
tim_f's Avatar
I also sit about the same distance and I am projecting on a 50"x67" (84") screen, and also using the same projector LT154. I think the picture looks great, and the size is just perfect for the room size.
tim_f is offline
Closed Thread Screens
