Da-Lite screens cheap to Sweden? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-09-2001, 01:00 PM - Thread Starter
ErikF's Avatar
Need to know a store that can send screens to Sweden.
Since we have added value tax of 25% (!) I need a cheap one:-)
I´m looking for one or more
Da-Lite 4:3 Model B Manual Rolldown 80 inch diagonal high power 2.8 gain
cousinsvideo won`t send abroad:-(
Please, help out!
Erik
ErikF is offline
post #2 of 3 Old 10-09-2001, 04:08 PM
Jason Turk's Avatar
Erik,
Drop me an email. I should be able to help you out.
Jason Turk
AV Science, Inc.
http://www.avscience.com
716-454-1460 ext.204
Jason@avscience.com
Jason Turk is offline
post #3 of 3 Old 10-09-2001, 09:14 PM - Thread Starter
ErikF's Avatar
Hi, Jason!
I mailed you last week, but I wanna check around.
The price you offered me was 399, but the freight was 150. If I add 25%, it´s to much. I can get it about 100 bucks cheaper or so from the UK.
I´m sorry tp sound like Scrooged (sp?), but my budget is down the train and my NEC LT150 has arrived:-)
Thanks anyway!
Erik
ErikF is offline
Closed Thread Screens
