screen for a HOT (100º) wall? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-11-2001, 05:13 AM - Thread Starter
Henry Schwartz's Avatar
My dilemma:
Need a small a small screen (60 inch diag)to mount on the back of a fireplace- bricks can get up to about 100 degrees when in use. Am I in for trouble? are there snap-mounted screens that won't suffer from the heat? I am hoping to go grey-
Henry
Henry Schwartz is offline
post #2 of 2 Old 10-12-2001, 04:44 AM
Guy Kuo's Avatar
The temp may soften the plastic and create a sagging problem over time. There is an easy solution. Use some steel L brackets, hole plates, bolts, nuts & washers and you can mount the screen frame six or more inches out from the "hot" wall. That will leave plenty of ventilation behind the screen to avoid long term problems.
Guy Kuo
www.ovationsw.com
Ovation Software, the Home of AVIA DVD
Guy Kuo
Guy Kuo is offline
Closed Thread Screens
