Anybody tried HomeDepot Drop Cloth for screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-11-2001, 03:14 PM - Thread Starter
Huey's Avatar
www.avsforum.com/ubb/image_uploads/dropcloth.jpg
It's 12'X15' with rubber backing and heavy duty. Is it a good screen material? Are there seams? What gain do you think it has? I thought this may make a good outdoor giant screen for my NEC LT150 at night http://www.avsforum.com/ubb/smile.gif
P.S. Model#=440-12X15, SKU#=469753, and UPC#=008411440125. It's available at my local HD (zip 45152).
Huey ;-]
[This message has been edited by Huey (edited 10-11-2001).]
Huey ;-]
Huey is offline
post #2 of 10 Old 10-12-2001, 02:24 PM
LynxFX's Avatar
Shoot, was just at home depot last night and forgot to look for this. I've started construction on my frame so if that cloth is cheap enough I might just try it out.
LynxFX is offline
post #3 of 10 Old 10-16-2001, 05:09 PM
jkaiser's Avatar
I bought one from HD that had the address of Green Bay WI, and some place in North Carolina - This was definitely seamed! It was an odd size though. I manage to get a 56" By 108" piece out of it.
I think it was KBK, but someone from Canada it think, said that there was a drop cloth at HD that was from Toronto or Montreal that was a single panel. That one unfortunately was not available at my local HD.
I also tried the canvas drop cloth at HD, this was also seamed.
I am currently using the 56 x 108 screen until the Rockland power buy comes through.
Failure is not an option. It comes bundled with every Microsoft product
jkaiser is offline
post #4 of 10 Old 10-17-2001, 01:15 AM
LynxFX's Avatar
I was at HD yesterday and looked at all of their drop cloths. The ones mentioned above were definately all seamed like said. I also didn't like the fabric. It didn't look uniform throughout. I did walk out with a $6 pure white, fiber-type drop cloth to try it out. Although it is quite thin and more paper like than canvas it worked alittle better than my white sheet. The wrinkles stretched out fine and a little brief ironing should work. I probably will just stick to my sheet though since it is already up and looks fine.
I hope this rockland buy through hurries up. :)
LynxFX is offline
post #5 of 10 Old 10-17-2001, 09:16 AM
JSilberlicht's Avatar
:D
I purchased the same dropcloth that you mention. You are correct it is more paperlike than a true canvas would be.
I did spend the time stretching it over my frame and painted it with Universal Gray.
I am extremely happy with the way it turned out. Color and grain is uniform throughout.
Works much better than my low-thread count sheet that I was using previously!
JSilberlicht is offline
post #6 of 10 Old 10-17-2001, 10:14 AM
bb80301's Avatar
Could someone please post additional info on this white fiber-type drop cloth?
- Size
- Department at Home Depot
- (if possible) SKU# or scan code #
BB80301
bb80301 is offline
post #7 of 10 Old 10-17-2001, 03:40 PM
LynxFX's Avatar
-bb80301,
The paper like drop cloth mentioned is:
Kimberly Clark
8'x12' Gotcha COVERED® Dropcloth
Model: #77002
SKU: #156051
$6.47
-JSilberlicht,
Sounds pretty good. I was just about to do what you did but the rockland buy just went through so I guess I'll wait my two weeks for that. Glad to see I wasn't the only one that thought this cheap drop cloth might work for a screen. :D
LynxFX is offline
post #8 of 10 Old 10-18-2001, 10:50 AM
bb80301's Avatar
Thanks, LynxFX!
bb80301 is offline
post #9 of 10 Old 10-18-2001, 01:18 PM
sstieferman's Avatar
Here's my 54 x 96" version that was made with the rubber drop cloth.
http://www.geocities.com/sstieferman
I haven't noticed any problems and the screen has been together for almost two years.
sstieferman is offline
post #10 of 10 Old 10-18-2001, 04:07 PM
REW
REW's Avatar
Yes this works unusually well.I am using 2 drops to get 7ft x 13ft at low cost.Est gain at around 1.0 I would like to try paint(GOO?) and get gain up to 2.5 to 3 range.Bet that would make me happy.Except for my other ongoing curved silver guys.:cool:
Ron
"Your priorities will be different-its the weighting that counts!-only if its done by FET!"
REW is offline
Closed Thread Screens
