DA-LITE HD Progressive build quality? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-18-2015, 08:30 AM - Thread Starter
Ruined's Avatar
Quoted: 100 Post(s)
Liked: 41
Hi all,
I currently have a Da-Lite Cinema Vision 1.3 screen that I got a few years ago and the screen does not appear to have aged well.
I have:
-Vertical striations in several areas of the screen
-Upper right corner has plasticizer leeching out (oil spot)
And, overall as I watch more on it over these past few years I am not happy with the heavy texture and sheen it has visible when panning in moderately bright scenes.
So on the whole, it is serviceable but has not been a great screen.
Luckily, I can easily adapt a DA-LITE HD PROGRESSIVE 0.9 screen to the same frame without breaking the bank. That would take care of the texture and sheen. But I am concerned about the build quality... Will this screen hold up over time or have the same issues my Cinema Vision had? Are vertical striations and the leeching plasticizers an issue with the HD PROGRESSIVE 0.9 as well?
The other option would be a Studiotek 100 but it would be much more expensive and I would have to remount the entire frame which would be a giant PITA.
Thoughts?
Ruined is offline
post #2 of 4 Old 07-19-2015, 08:50 AM
DavidHir's Avatar
Quoted: 579 Post(s)
Liked: 649
I did own the HD Pro 0.9 for a brief period of time, so I cannot stay for certain since it was for such a short time as I ended up going with the Stewart ST100. But, I didn't see anything about the surface of the material that would make me concerned about those things. The material is very smooth and there are a few sparklies in it, but I doubt those would cause issues over time. I have not read of many issues with the HD pro materials in general. As you probably know, it's technically a grey screen but does not look like one at all. It looks closer to white with an ever so slight blue tint vs grey. I think you'll be very happy with it so long your projector has sufficient light output and the environment is ideal for it. Your 1.3 gain screen (if that is a true gain) will be far, far brighter.
DavidHir is offline
post #3 of 4 Old 07-20-2015, 10:48 AM
Craig Peer's Avatar
Location: In my home theater ( when I'm not rock climbing, cycling or kayaking ) - Sacramento CA area
Quoted: 988 Post(s)
Liked: 696
Originally Posted by Ruined View Post
Hi all,
I have:
Thoughts?
I had a High Contrast Cinema Vision screen that I could see the same vertical screen texture on. not sure if that got worse with age or I just noticed it more as I got better and brighter projectors, and moved my seating closer. I haven't heard of many problems with the HD pro material myself.
AV Science is a Da Lite dealer - shoot us an email and maybe we can help.
Craig Peer, AV Science Sales. Call me on my direct line - 585-671-2972, 8:30am - 4:30pm PST, Monday - Friday
Email me at craig@avscience.com http://shop.avscience.com/
Yes, we sell Home Theater gear right here at AVS !!
JVC, Sony, Epson, DPI, SIM2, SV Sound, Martin Logan, RBH, and many more!
Craig Peer is online now
post #4 of 4 Old Today, 08:14 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1888 Post(s)
Liked: 1014
Hi all,
I have:
Thoughts?
Earlier versions of Cinema Vision also seemed to yellow over time. Current versions of Cinema Vision seem to do better. Have not heard of that happening with HD Pro.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Sony, JVC, Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, SVS & Def Tech, Denon, Marantz, Yamaha & MiniDSP.
AV Science Sales 5 is online now
Reply Screens
