Cinema-Choice vs Elite Spectrum vs EluneVision Titan - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-07-2015, 07:32 PM - Thread Starter
Liked: 0
Has anyone heard of Cinema Choice, Model: TTE106MW
Trying to buy a screen in Canada and have narrowed it down to the following in PRI order...
1) $579.99 (Costco) - Cinema Choice 106-in. Tab-Tensioned Motorized Projection Screen
2) $548.89 (Amazon) - Elite Screens Spectrum Tab-Tension
3) $790.63 (Staples) - EluneVision Titan Motorized Tab-Tensioned
If anyone has any other recommendations would love to hear:
Couch is 11 feet from screen, 80" ceiling height, going to mount inside celling joists. I'm also scared about speaker placement, if i need an Acoustic screen or if mounting under/side is ok...
Thanks again
spids is offline
post #2 of 13 Old 09-10-2015, 10:17 PM
bobbyk1133's Avatar
Thanks again
I too was looking at the Cinema Choice screen at Costco. They are local, and make budget level screens, but beyond that there is no other info online.
If others could vouch for their screens, I just might pull the trigger on it.
bobbyk1133 is online now
post #3 of 13 Old 09-11-2015, 05:09 AM
Thrillho's Avatar
Quoted: 14 Post(s)
Liked: 33
I had the Titan, it was ok. I traded up to the reference 4K and it was worlds better. What part of Canada are you in?
Thrillho is offline
post #4 of 13 Old 09-11-2015, 05:50 AM
Quoted: 1620 Post(s)
Liked: 414
Can you please provide some specifics comparing Reference 4K with Titan?
Dominic Chan is online now
post #5 of 13 Old 09-11-2015, 06:23 AM
Thrillho's Avatar
Quoted: 14 Post(s)
Liked: 33
The titan had a very visible texture that produced a shimmering that VERY noticeable on bright solid scenes, think light blue skies in movies or most solid textures in video games. This drove me crazy. From what I've seen, this is a symptom of cheaper screens and you're going to see it to some degree in most entry-level screens. The Reference 4k on the other hand is absolutely invisible. There is zero texture, everything is sharper and clearer due to this. Also, my Titan developed some slight waviness but where I moved to a fixed frame on the Reference, I'm not going to call that a "Win" as the Retractable reference could be just as likely to exhibit that.
All and all, when I first got my projector I was wowed by the size and the film like quality but quickly started to pick up on the negatives like the texturing and the sharpness. I still loved it but could see the flaws and felt while it was huge, my plasma delivered a much better overall picture. Once I switched the screens out my opinion changed immensely, my proj was now delivering a picture that I was 100% satisfied with. That was a year ago and I'm still very pleased.
Both screens were the Matte White standard gain option (1.2 for the Titan, 1.0 for the Reference). I also owned the Matte Grey manual pull down for about a week and that was plain bad. The mechanism broke very quickly and tore the screen, it had the same texturing as the titan, and my projector was nowhere near bright enough to overcome the grey.
Thrillho is offline
post #6 of 13 Old 09-11-2015, 12:38 PM
Liked: 414
Thanks for the info.
The Elunvision 1.2 gain screen material is called "Cinema White". Whatever they use to provide the additional gain is likely what's causing the shimmering. "True" matte white screens, even entry-level screens, should not have any shimmering.
post #7 of 13 Old 10-05-2015, 03:23 AM
Liked: 1
Was looking at the exact same screens, especially the one from Costco. I'm in Nova Scotia close to you Thrillho.
Where did you buy yours?
cyberphox is offline
post #8 of 13 Old 10-08-2015, 07:30 PM
Thrillho's Avatar
Quoted: 14 Post(s)
Liked: 33
I bought mine from EastPorters. Check your PMs.
Thrillho is offline
post #9 of 13 Old 10-12-2015, 06:34 PM
Liked: 1
post #10 of 13 Old 12-31-2015, 04:30 AM
sharp10's Avatar
Hi guys, is there any other opinions on the cinema choice? I was wondering as well.
sharp10 is offline
post #11 of 13 Old 12-31-2015, 04:33 AM
sharp10's Avatar
Thanks again
Did you make a final decision?
sharp10 is offline
post #12 of 13 Old 01-14-2016, 06:34 AM
Pedro6's Avatar
Would you guys highly recommend the Reference 4k over any of these other choices?
Pedro6 is offline
post #13 of 13 Old 01-20-2017, 07:52 AM
jterpstr's Avatar
Liked: 0
Anyone else have any input into the Cinema Choice fixed screens? Costco has what appears to be a fantastic price on a 110" Acoustic Transparent Fixed-Screen and I'm thinking of picking it up.
jterpstr is offline
Reply Screens
cinema choice , elite spectrum , elunevision
