High gain 150 inch screen for under $1200?? - AVS Forum | Home Theater Discussions And Reviews
Old 02-19-2016, 10:52 AM - Thread Starter
totalimpact's Avatar
I am looking at installing a Epson EX7240 projector in a classroom, it looks like optimal throw is at 15 feet or more, which gives me a 150" image.
http://www.projectorcentral.com/Epso...ulator-pro.htm
The room has a lot of windows and they are shaded, but not very well.
Can anyone recommend a source for a screen under $1200 that has a 1.2-1.5 gain??
Manual pull down is fine, cant do fixed frame, as the screen actually overlaps a window.
totalimpact is offline
Old 02-21-2016, 09:20 PM - Thread Starter
With advice from the vendor, I finally found this one, 1.5 gain under $700... local vendors of course quoted $2500:
http://www.projectorscreenstore.com/...reen-8035.html
