Dedicated HT - Dark room, no windows - ALR? - AVS Forum | Home Theater Discussions And Reviews
Old 03-21-2016, 07:26 PM - Thread Starter
Pelly_NV's Avatar
Quoted: 44 Post(s)
Liked: 31
Finally able to have a dedicated HT in our new house (~17' deep / no windows) and planning on using a matte finish darker paint. No lights will be on while viewing.
Looking to use a JVC X550R and wondering what I should go with for a high-end screen. Main question is, do ALR screens have any benefit in a room like this? Seem to be reading contradicting info online...
I'm in Austin, TX so I'm somewhat gravitating to SI.
Pelly_NV is offline
Old 03-21-2016, 07:40 PM
bud16415's Avatar
Quoted: 785 Post(s)
Liked: 277
Very little advantage if any.
Bud
bud16415 is online now
Old 03-21-2016, 08:35 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
No, a properly built room with proper reflected light control is where you use a white, color neutral, texture free, utility gain screen.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 03-22-2016, 01:23 AM
Ftoast's Avatar
Quoted: 1919 Post(s)
Liked: 625
And please don't buy the SI white..it pushes more blue than some screens at 1/2 the price or less.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is online now
Old 03-22-2016, 07:35 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
This report may help you understand the differences and why one screen is better for one room than another.
http://www.accucalhd.com/wp-content/...een_report.pdf
Doug
Old 03-22-2016, 09:09 AM - Thread Starter
Pelly_NV's Avatar
Quoted: 44 Post(s)
Liked: 31
This is exactly what I was looking for, thank you!
Thx for the other responses as well folks.
Pelly_NV is offline
Old 03-22-2016, 09:21 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3039 Post(s)
Liked: 2972
In your situation I would go with a white screen for sure - Stewart Cima Neve, StudioTek 130 G3 or similar. Which is what I have myself ! Give us a call if we can help.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
