Grey Screen to Improve Blacks - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By Craig Peer
  • 2 Post By mesasone
  • 2 Post By Dave in Green
  • 1 Post By bud16415
  • 1 Post By DavidHir
  • 1 Post By mhconley
post #1 of 21 Old 04-14-2016, 10:25 AM - Thread Starter
Beerce's Avatar
Hi all,
I'm wondering if there is sound logic in using a grey screen in a completely light-controlled room to "artificially" improve black level performance. Projector in question is a Sony HW40ES which has no iris. I know grey screens can be used in rooms with ambient light to help out there but can the same principle be applied in a fully dark room to achieve better blacks than in the same room with a while 1.0 gain screen?
Trade off is brightness on the screen, but the 40ES is a fairly bright projector anyways. I can light a 138" 2.35:1 white screen or consider a smaller grey screen if it might produce better blacks. Keep in mind we are not talking about having any ambient light.
Have I misunderstood anything here? Is the white screen generally the way to go in a light-controlled room, or does a grey screen potentially present a way to artificially lower the native on-screen contrast?
Beerce is offline
post #2 of 21 Old 04-14-2016, 10:37 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3029 Post(s)
Liked: 2959
Originally Posted by Beerce View Post
Hi all,
The best way to preserve the black levels your projector is capable of ( if you really want better black levels, you'll need a projector capable of better contrast ), in my experience, would be to treat your room to reduce or eliminate reflections.
Before -
After -
Made a world of difference. In fact, I have better contrast now with a white screen than I did before with a grey screen, and a brighter picture too !
DavidHir likes this.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #3 of 21 Old 04-14-2016, 10:42 AM - Thread Starter
Beerce's Avatar
Hi Craig,
Yes, I will have the entire room painted or treated in some way to make it black, including the ceiling.
I suppose my question is with all of those things already in place, would a grey screen improve the blacks? Assume no light, fully black room and furniture.
By the way, your before/after pics don't seem to be loading for me.
Beerce is offline
post #4 of 21 Old 04-14-2016, 10:44 AM
mesasone's Avatar
I think you certainly could do this, but you would be better off taking care of any light rejecting back on to the screen first. Then consider a darker screen if you still find the blacks lacking. As a bonus you'd get more contrast when ambient light is present.
skypop and Ftoast like this.
mesasone is offline
post #5 of 21 Old 04-14-2016, 11:16 AM
emergetech's Avatar
Liked: 9
Here is a recent review from Sound and Vision on the Seymour Screen Excellence Ambient-Visionaire Black 1.2 Projection Screen where the author claims this screen will even raise the contrast and black levels from budget projectors.
http://www.soundandvision.com/conten...Dw02iQKfF3C.97
emergetech is offline
post #6 of 21 Old 04-14-2016, 11:37 AM - Thread Starter
Beerce's Avatar
Alright upon further research (which I did before posting, but hadn't found enough convincing info until now) I am concluding, that for myself, in a dark room with full light control and non-reflective surfaces, a white screen is going to be my choice. The blacks may be slightly improved by a grey screen, but I think the sacrifice made in colours and bright scene contrast will outweigh (negatively) the improvement in blacks.
Still interested to hear any real-world experience with this concept and other opinions.
Beerce is offline
post #7 of 21 Old 04-14-2016, 11:50 AM
Dave in Green's Avatar
Quoted: 1283 Post(s)
Liked: 852
In an optimized room with no ambient light and dark surfaces that don't reflect light coming from the screen back onto the screen there is no advantage to a grey screen over a white screen unless your image is too bright for the white screen and you want to reduce the brightness of everything in the image. As much as the grey screen will darken the blacks it will equally darken the whites and everything in between.
The advantage of a grey screen is realized in a non-optimized room with some ambient and/or reflected light from lighter-colored surfaces. In that case if you go from a 1.0 gain white screen to a sub-1.0 gain grey screen the grey screen will reflect less ambient light. It will also reflect less light from the projector, so you need to be able to increase projector lumens to an appropriate level to compensate for the grey screen absorbing more lumens than the white screen. Since ambient/reflected light remains the same, what you are doing in that case is increasing the ratio of projector lumens to ambient/reflected light lumens hitting the screen.
All of the above assumes a neutral grey lambertian screen with sub-1.0 gain and not an ALR screen that is grey but with positive gain that results in a narrower viewing cone.
FreMo and Ftoast like this.
Dave in Green is online now
post #8 of 21 Old 04-14-2016, 11:53 AM
bud16415's Avatar
Quoted: 784 Post(s)
Liked: 277
A perfect room go with a white screen. The one exception is my case I have a perfect room or close to it and have a gray screen the reason being is I want a perfect image with every light off in the room and the room catching all the stray light all I need is extra lumens and the image is exactly the same as white. BUT when I watch the super bowl with a bunch of people or a UFC bout or want to watch a tv movie on the screen and eat a pizza and make it a more social setting I can do that with well-directed controlled ambient lighting. You can also do that with a white screen but not as well. I can watch a tv and she can easily read a book at the same time.
If you are always going lights out, go white and save the lumens. I’m never quite sure where they go when you save them but at least stay in eco mode.
skypop likes this.
Bud
bud16415 is offline
post #9 of 21 Old 04-14-2016, 12:22 PM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1319
Stick with a white screen with the least amount of screen texture and get your room as much of a black pit as possible.
Craig Peer likes this.
DavidHir is online now
post #10 of 21 Old 04-14-2016, 12:38 PM - Thread Starter
Beerce's Avatar
Settled enough for me. Thanks again to all.
Beerce is offline
post #11 of 21 Old 04-19-2016, 04:30 AM
FreMo's Avatar
Quoted: 61 Post(s)
Thanks for the explanations.
I have a Sony 65 projector in a white living room. Furthermore, I can t use the low lamp mode because of some flickering issue. So I will go to a grey screen.
FreMo is offline
post #12 of 21 Old 04-19-2016, 06:42 AM
mhconley's Avatar
Quoted: 102 Post(s)
Liked: 74
You should consider a true Ambient Light Rejecting (ALR) screen and not just a grey screen. In a non-light controlled room a grey screen will just give you slightly grayer blacks. An ALR screen will give you blacker blacks by rejecting the reflected light. They actually work by shunting the reflection off in a direction away from your eyes whereas a grey screen will reflect it right back to you.
Martin
Surfdrifter likes this.
Home Theater System: Panasonic PT-AE8000U; 138" 2.35:1 Silver Ticket Silver ALR, Pioneer Elite SC-75; Klipsch Reference RF-82 II, RC-62 II & RS-52 II; 2 Reaction Audio Echo 15 subs; Comcast DVR / PS3 / WiiU / Xbox One
Stereo Audio System: YS-Audio Audio Experience Balanced A2; DIY ICEpower 1000ASP monoblocks; Von Schweikert VR-4 Gen III HSE; PS Audio Digital Link III; Logitech Squeezebox Touch; PS Audio GCPH; Opera Consonance LP-2.0; Mørch UP-4; Grado Sonata; PS Audio GCHA; Sennheiser HD 598
mhconley is offline
post #13 of 21 Old 04-19-2016, 07:12 AM
FreMo's Avatar
Quoted: 61 Post(s)
Martin
Thanks for the information, do you have some product example?
FreMo is offline
post #14 of 21 Old 04-19-2016, 08:03 AM
mhconley's Avatar
Quoted: 102 Post(s)
Liked: 74
Projector Central recently reviewed a slew of them: http://www.projectorcentral.com/ambi...-screens-2.htm
Add to that list in no particular order:
  • Elite Cinegrey 3D and 5D
  • Dark Energy Abyss
  • Silver Ticket Silver ALR
  • Elunevision Aurora (not yet released)
Then you have the whole DIY painted ALR screen thread: Easy Ambient Light Rejecting Screen Paint
Martin
mhconley is offline
post #15 of 21 Old 04-19-2016, 08:26 AM
bud16415's Avatar
Quoted: 784 Post(s)
Liked: 277
Martin
That only works if the ambient light is coming from someplace above or off to the sides and not from the direction of the viewers. The screen can’t tell the difference between projected light and all other light.
On the other hand a gray with low gain high dispersion will absorb ambient light coming from all directions. But does require higher lumens from the projector to overcome the lower gain.
Bud
bud16415 is offline
post #16 of 21 Old 04-19-2016, 10:12 AM
mhconley's Avatar
Quoted: 102 Post(s)
Liked: 74
Correct. The vast majority of ambient light, especially in normal living rooms, not batcaves, is reflected from the walls, ceiling and floor onto the screen. That is what ALR screens are made to alleviate. Light coming from behind the projector will be reflected back into the viewers eyes by any screen, albeit slightly less on a grey screen, 20% less on a 0.8 gain grey vs a 1.0 gain white screen. Hopefully light from that direction can be dealt with in other ways.
Martin
mhconley is offline
post #17 of 21 Old 04-19-2016, 10:20 AM
Stanton's Avatar
Quoted: 1411 Post(s)
Liked: 741
I used a sub-1.0 gain (grey) screen with a high-lumens projector for years with excellent results (I removed it from my sig a year ago: Optoma HD65 projector with a Da-Lite Hi-Contrast screen); it definitely improves the perception of blacks with front projection. However, since I got my OLED and it's "perfect blacks", I haven't watched a single movie with my projector!
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is offline
post #18 of 21 Old 04-19-2016, 10:30 AM
Liked: 852
By definition ALR screens have narrower viewing cones than lambertian screens. ALR screens are also more likely to have visual artifacts such as hot spots, sparkles, etc. Finding just the right ALR screen with the fewest compromises for a given room environment can be challenging.
post #19 of 21 Old 04-19-2016, 11:02 AM
bud16415's Avatar
Quoted: 784 Post(s)
Liked: 277
Martin
That’s only somewhat correct with a lambertian gray screen and light coming from the direction of the viewers because of the 180 degree dispersion very little of that light comes back to the viewer as most fills the wide dispersion areas and is thrown to the walls. In a dark screen with angular gain more of that ambient is brought back into the viewing cone. All light projected and ambient bounces around the room endlessly until something absorbs it. The gray properties of the screen will absorb first reflections and 2nd 3rd …. As will dark objects in the room walls and ceilings. With a dark screen and dark walls and ceiling they work together as a light trap. An ALR screen with windows to the left and a white wall to the right that is lambertian white as most paint is more or less will redirect the window light to the wall but then the wall redirects it in all direction around the room.
Bud
bud16415 is offline
post #20 of 21 Old 04-19-2016, 01:13 PM
mhconley's Avatar
Quoted: 102 Post(s)
Liked: 74
I'll have my first ALR screen in my room setup by next Saturday; it's my first screen of any type. Most my viewing will be a night with a white ceiling and floor and a tan wall on the left side of the screen; there is no wall on the right. Some viewing will be during the day; there are two windows on the left wall with blinds; the right side of the room has several large windows with no light control but they are more than 25' away. I'm hoping the Silver Ticket Silver ALR I bought will do the trick...
Martin
mhconley is offline
post #21 of 21 Old 04-20-2016, 04:29 AM
bud16415's Avatar
Quoted: 784 Post(s)
Liked: 277
Martin
I think you should be very happy with your screen selection. I know you have been doing your homework and it sounds like your room is well suited to your screen.
Bud
bud16415 is offline
Reply Screens
