Cleaning an LED screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-21-2016, 07:36 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 6
I have a disabled child in the house that likes to spit in her hands and slap things. So my Samsung 75 inch LED screen has spit and wet hand prints dried up all over it.
Soft cloth pads that come with my 3D glasses just smudges it even more. I then tried microfiber cloth. Same thing. So i bought a solution for cleaning lcd screens, and the spit and hand prints are gone but now there are streaks all over the entire screen. It's impossible to get off. I'm afraid to use anything else, so i was wondering if any of you had an ideas for heavy duty cleaning a 75 inch LED screen.
HailKingCeezer is offline
post #2 of 2 Old 06-23-2016, 10:14 PM
acras13's Avatar
Quoted: 117 Post(s)
Liked: 102
Not sure why the screen cleaner isn't working , your LED is an LCD screen , the backlights are LED . Check with the manufacturer as to what to use because I think some of the screens have different recommendations .
You should also move your question to the proper area to get better responses , this is the projector screen section , different animal . Good luck.
It was like that when I got here
acras13 is offline
Reply Screens
