Curves in new screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-18-2017, 05:31 PM - Thread Starter
bruin27's Avatar
So I just finished putting my elite screen together and hung it. Unfortunately mostly at the top I have curves, probably more tension in the bottom springs pulling the screen down more in certain areas.
Does anyone know how to fix it? Or am I SOL?
bruin27 is offline
post #2 of 4 Old 09-18-2017, 05:38 PM
michael hurd's Avatar
Quoted: 156 Post(s)
Liked: 131
It looks like you need more tension side to side in order to take up those wrinkles. Before anything else, I would try a hair dryer a few inches away from the screen to gently warm the screen, that may help with the wrinkles, making sure you are continually moving the hair dryer as to not get the screen too hot.
95% Synthetic bass since Y2K.
michael hurd is offline
post #3 of 4 Old 09-18-2017, 05:39 PM - Thread Starter
bruin27's Avatar
It's not wrinkles, just looks like springs on the top aren't pulling equally as the bottom ones
bruin27 is offline
post #4 of 4 Old 09-19-2017, 06:33 AM
Quoted: 44 Post(s)
Liked: 25
I concur with the previous posters, I have an Elite Curved Screen, and it is important that you follow the instructions to the letter to ensure your screen is properly aligned and adjusted. This was done in several steps in accordance with the included instructions. Hope this helps.
Peace and blessings,
Azeke
Azekecse is offline
Reply Screens
