The Official Stewart Film Screen thread. - Page 65 - AVS Forum | Home Theater Discussions And Reviews
 200Likes
post #1921 of 2508 Old 08-11-2014, 12:09 PM
Bagis's Avatar
Originally Posted by m Robinson View Post
Hello Mr. Bagis,
First, Thank you very much for selecting Stewart Filmscreen for your display! We appreciate the business!
Here is what I would do.
Deploy the screen
Lift the batten on the end you wish to about an inch, or 30 millimeters.
The ferrule which anchors the side cord, is spring loaded. Push it gently down into the batten.
The hex-head bolt will emerge from the bottom of the batten. It's usually easy to move by hand, but if not, use a 5/16" wrench, or a pair of pliers to turn it.
Loosen that hex head about six full turns.
Allow the batten to drop to its normal position.
The side cord should be noticeably looser. If not, repeat the steps.
At the end of the process, you want the side cords to be just tight enough to hold the sides out in position, but no tighter.
If you need more assistance call (800)762-4999,and our Customer Service folks will walk you through it. If you are calling from an international location, use (310)784-5300. Extention 145.
Great, thanks for your quick response M Robinson. I have applied it and it works, no more worries for me!
BR//Bagis from Sweden
Bagis is offline
post #1922 of 2508 Old 08-13-2014, 07:00 AM
LJG
LJG's Avatar
Quoted: 385 Post(s)
Liked: 190
Hello LJG,
Thank you for being a long term Stewart Filmscreen Customer! We appreciate the business.
Does the fabric deploy too far at the bottom of the travel, as well as stopping short at the top?
If not then we only have to address the top stop. Of the two holes you have there, the up stop should be in the lower hole. Run the fabric down to the lower stop. Take a 5/32" tee handle hex wrench and insert it in the hole. Turning the limit switch counter clockwise will increase the travel, therefore allowing more material retraction up into the fascia. Turn that screw counterclockwise two full turns. Run the panel up, leaving your t-handle hex wrench in position. When the panel stops, you can keep creeping the limit upward, by continuing to turn counter clockwise.
Check the bottom limit too. The Somfy progressive limits always require a counter clockwise turn to increase motor travel in the direction you are adjusting.
If a satisfactory solution continues to elude you, call our factory Customer Service line at (800) 762-4999 extension 145. Good Luck!
Unfortunately turning the limit switches did not increase or decrease the travel. I have call into tech support
LJG is online now
post #1923 of 2508 Old 08-18-2014, 09:04 AM
dvzzz's Avatar
Quoted: 108 Post(s)
Liked: 31
Question Need an opinion on the projector placement for Firehawk G4
Appreciate an advise from Stewart owners or experts on the placement for JVC X-3 projector against Firehawk G4. I have a JVC X-3 that is sitting 12 feet away from the screen on the 27-inch tall coffee table about 10-inch to the right of the screen's center so I am using shift on it, my head is 39-inch from the floor. Screen that I need is 105". I keep reading that Firehawk will lose a lot of light output if I place it against my setup? I am trying to validate if this is the case with G4 as well.
Thank you!
dvzzz is online now
post #1924 of 2508 Old 08-28-2014, 07:20 AM
BrutaleZEN's Avatar
Hey Guys,
do you know where I can buy a Quick Snap Wall Mount for my 100" Studio Tek 130 Luxus Deluxe screen ?
Thanks a lot for your help.
Regards
Denon AVP-A1HD with 3D upgrade, Denon POA-A1HD, Klipsch THX Ultra 2 7.2 speakers, Oppo BDP-103D, Toshiba HD-A35, Oppo DV-983H, Samsung Satellite Receiver, JVC DLA-RS6710, Stewart Screen 16/9 Studiotek 130 G3 100", Mac Mini as a media center, NAS Synology DS 1812+, Drobo Pro 800 storage unit, Sony...
BrutaleZEN is offline
post #1925 of 2508 Old 08-28-2014, 01:52 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3396 Post(s)
Liked: 3374
Originally Posted by BrutaleZEN View Post
Hey Guys,
Regards
If you are in Bangkok, maybe it would be easier to fabricate something locally ?
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #1926 of 2508 Old 08-28-2014, 10:44 PM
BrutaleZEN's Avatar
Hey Craig,
I already did, but frankly the job done is far from great, and my screen hang on a false wall, there is a false window at the back of my false wall that I have to unscrew to access the actual window that allow me to service the compressor for my air conditioner (yep, not a simple set up).
The thing is with the brackets that I have, it took me 1 or 2 hours to try to hang the screen ... kind of frustrating. I want the original Stewartfilm stuff that was designed by professionasl .... So I don't get aggravated when I want to service the air con compressor ...
I have an address in California, so not difficult to order stuff from the US.
Thanks again.
Regards
post #1927 of 2508 Old 08-31-2014, 10:30 AM
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
A couple questions related my upcoming (in progress actually) room build.
Right now, what is spec'd by Dennis Erskine is an Electrivertimask with a Studiotek 130 microperf screen (132" wide 2:35)
1. Previously, everything I've read is that past 10-11' feet, you don't see the microperfs. However, in my build thread, a number of people have talked about seeing them far past 11', including talking about seeing them more like in the 15-17' range. Also, that on very light scenes of movies they are more visible than in dark scenes. So, what's the story on visibility. I have a sample coming, but as my room isn't constructed, I don't have a real accurate way have testing this. I'm leaning towards the Stewart, but don't want to get into a situation of seeing the perfs all the time and regretting it (my primary seating row will be between 12-13' (still a couple minor details left that will decide exactly how far from eyes to screen).
2. This will be an aperture mount install into a screen wall. There will be zero access behind the screen (such as to work on speakers) other than through the screen frame. I was assuming one of the advantages to the Stewart was being able to unsnap the screen (or part of it) to be able to get back to the speakers if I need to make any tweaks. Someone pointed out that this is not as easy as I seemed to think.
Anyway, any thoughts on either of my two points above would be appreciated.
Tnedator is offline
post #1928 of 2508 Old 09-01-2014, 01:19 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 188 Post(s)
Liked: 151
Stewart says 10' and Erskine says that's the screen form your theater; You've hired a pro to tell you what to use, opinions here should not come into it much IMO. Say 3 guys here say you can see them, 6 say you can't. Then what? And the bigger question, what are you gong to use otherwise? Your choices move to woven screen options that suck light. Now your projector isn't sized properly, or you need a different screen size, and it dominos from there to other theater issues. Work with your designer. He knows what he's doing.
Tnedator likes this.
GetGray is online now
post #1929 of 2508 Old 09-02-2014, 01:45 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3374
Hey Craig,
Thanks again.
Regards
Send me an email and I'll see what I can do.
post #1930 of 2508 Old 09-08-2014, 07:58 AM
tanwn1's Avatar
Quoted: 89 Post(s)
I have black wall n ceiling and would like to go for 130inch diagonal 2.35 screen. Should I go for studiotek 1.3 or use a lower gain screen 1.1? Any issue with hotspotting? Using jvc x700
tanwn1 is offline
post #1931 of 2508 Old 09-08-2014, 03:35 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3374
Hot spotting is related to throw distance. What is your throw distance ?
post #1932 of 2508 Old 09-09-2014, 11:42 AM
drlopezmdfacp's Avatar
I have a brand new motorized stewart screen and I just noticed some marks on one of the sides as if the screening is rubbing against the roller. I am concerned because I have had the screen for less than a month. Sent same inquiry to installer. Is this fixable? Suggestions?
ID:	254738   Click image for larger version
ID:	254746   Click image for larger version
drlopezmdfacp is offline
post #1933 of 2508 Old 09-17-2014, 07:10 PM
Liked: 0
Stewart Studiotek 130 G3
Hello, kind of a newbie here. Iam trying to decide on what size screen to go with in my dedicated HT. I like the ST 130 because of all the reviews i have read. My room is roughly 14' wide by 28' depth, drop ceiling is 7' 8" from floor. Iam considering 1.78 or 2.35 screen. I would like to get the biggest screen size i can get without going too big. My problem is the height from floor to ceiling. The wall the fixed screen will be mounted on is 14' wide. Any suggestions on how high the bottom of screen needs to be from floor. I had taped off for a 130" 16x9 screen on wall, ended up being 20" from floor & that was coming off ceiling 2". Might be better off going with a 2.35 screen...any suggestions would be highly grateful.
towns01 is offline
post #1934 of 2508 Old 09-18-2014, 09:55 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 3374
The bottom of my 122" diagonal 1.78:1 screen is 17" off the floor ( bottom of viewing surface ). It's perfect height wise.
post #1935 of 2508 Old 09-27-2014, 05:59 PM
Quoted: 16 Post(s)
Liked: 0
I have the opportunity to buy a used G2 123' Firehawk that I believe is about 6-7 years old, but only used for 3-4. I'm struggling to find a good asking price. Also, how long do screens usually last.... assuming it was well taken care of?
Ryan Rosser Byorick is offline
post #1936 of 2508 Old 09-29-2014, 08:07 AM
Mike Garrett's Avatar
Quoted: 6068 Post(s)
Liked: 3896
Mounted low like 20" is great, as long as your feet do not block your view, when reclined.
mjgarrett100@gmail.com
Mike Garrett is offline
post #1937 of 2508 Old 09-29-2014, 03:02 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3374
Easily 15 - 20 years I would think. Sort of depends on the environment - cool, clean, dark - maybe 25 years.
post #1938 of 2508 Old 09-29-2014, 03:56 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3374
As always, everything depends on ones theater layout. I for one do not have recliners. Folks just pass out in them and fall asleep.................I'm running a home theater, not a motel !
post #1939 of 2508 Old 09-30-2014, 09:31 AM
Liked: 3896
With 10,000 watts on tap, nobody falls asleep in my theater.
post #1940 of 2508 Old 09-30-2014, 09:34 AM
Frohlich's Avatar
Quoted: 1177 Post(s)
Liked: 1127
I have 10,001
Frohlich is offline
post #1941 of 2508 Old 10-03-2014, 08:26 AM
Liked: 3896
Originally Posted by Frohlich View Post
I have 10,001
I know your set up and I bet nobody falls asleep in it.
post #1942 of 2508 Old 10-14-2014, 08:57 AM
HTmarket's Avatar
Quoted: 213 Post(s)
Liked: 51
Stewart Screen Material Guide
We did a comparison between Umatte 150, ST 130 and Firehawk. I thought this would be helpful for stewart owners who want to upgrade their screens or new people interested in stewart, This addresses the most common question we get on Stewart.
Alan Hutchinson
HTmarket.com
HTmarket is online now
post #1943 of 2508 Old 10-14-2014, 11:13 PM
David Shapiro's Avatar
Quoted: 71 Post(s)
8 year old Stewart screen, ceiling mounted, retracted up mid-show and now won't come down. Since it retracted, can I assume that the motor still works and it is a cable issue? I'm going to call my installer tomorrow.
David
DES
David Shapiro is offline
post #1944 of 2508 Old 10-15-2014, 07:10 AM
HTmarket's Avatar
Quoted: 213 Post(s)
Liked: 51
Try Stewart Tech support
I would try Stewart Tech support on it, they may have seen the issue before.
Alan Hutchinson
HTmarket.com
post #1945 of 2508 Old 10-15-2014, 05:27 PM
R Harkness's Avatar
Quoted: 1990 Post(s)
Liked: 1703
Just a couple quibbles from that video since there are a few parts that could be misleading...
1. The gentleman in the video talks of "losing detail" when using the Firehawk sample compared to the ST130. That could make someone who didn't know any better believe that the Firehawk actually causes images to lose detail. "Well, I don't want to lose image detail, so why would I use a Firehawk?" The Firehawk material doesn't inherently lose detail. It simply makes the image more dim, making some detail a little harder to see. But any screen with a lower gain would do the same. Simply adding brightness to the projected image (e.g. moving the projector closer, using a brighter projector, opening up a manual iris if one is employed) to equalise brightness would make the detail just as visible as on a white screen. So it's just a function of brightness.
2. "I still think the Firehawk G3 was made for improving the contrast on projectors vs dealing with light."
There's been a long history of people presuming gray-based screens somehow magically improve the contrast of projectors, simply by virtue of being gray based or whatever. They don't.
A screen, whether it's a firehawk or a neutral white screen, does not improve the native contrast image of a projector. That's not possible as the screen simply reflects back whatever contrast the projector is putting out. The Firehawk was designed to improve the projected image contrast in situations where it could be compromised by ambient light and/or reflective room surfaces. (It does so by using a darker substrate material that helps lower the level of stray light on the screen, while using an optical coating to focus light more directly back to the viewer vs a neutral screen,
to maintain decent image brightness at the viewer location, and to direct less light on to adjacent room surfaces to mitigate reflections).
Cheers,
ben38 and Craig Peer like this.
R Harkness is offline
post #1946 of 2508 Old 10-16-2014, 11:20 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 3374
Cheers,
You can't compare gray and white screens very fairly together like that - your eye is always drawn to the brightest image. And everything you said Rich is spot on. With a full sized Firehawk, your eyes would adjust to the brightness.
post #1947 of 2508 Old 12-12-2014, 04:42 PM
mike123abc's Avatar
I am considering a new screen. My room is not a dedicated home theater. During most viewing the lights are all off and the windows are blacked out, but the walls are very light, the ceiling is white and most of the furniture is white. So, ambient light is not the problem, reflected light is the problem. Currently I have elite screens 92" (diagonal) cinegrey, and a new Sony VPL-HW40ES. The Sony is 3x brighter than my previous projector. I would like to go to 100", or maybe 110". The projector lens is 12' 8" back from the screen and cannot go further back (currently about 5" off the back wall).
Looking through the Stewart Screen's offerings it looks like perhaps the Grayhawk RS G4 may be the best option for my room. The main problem I see is that the projector may be too close for a larger screen, given the 1.5x screen to projector Stewart specs.
So, my basic questions are:
1. Is this screen a good match for my room conditions? Or would a different one be better?
2. Is the projector too close for hotspots with 110" screen?
3. My projector is fairly centered, about 4" below the top of the 92" screen. I could drop it down lower probably a foot, and a larger screen would actually be mounted higher on the wall, so the projector would be effectively lower, would that improve hot spotting?
mike123abc is offline
post #1948 of 2508 Old 12-12-2014, 05:17 PM
GetGray's Avatar
Quoted: 188 Post(s)
Liked: 151
Do not get the GH fo rthis application. It's not what it's designed for. It will wash badly with any ambient or reflected light. Firehawk is best for rejecting reflected or ambient light. PM me if you need help getting one or choosing the right one. Scott
post #1949 of 2508 Old 12-12-2014, 05:32 PM
Stan-Lee's Avatar
I agree. Firehawk G4 or LA is the screen you need. It's what I have in similar conditions!
Stan-Lee is offline
post #1950 of 2508 Old 12-12-2014, 05:45 PM
mike123abc's Avatar
The issue I see with the firehawk is the off axis viewing. The Firehawk looks to be 35 degrees to 50% vs 77% with the Grayhawk. The gain is not really an issue, given how bright the projector is (too bright really for 92" screen even in gray, find myself squinting on bright scenes). This is not a dedicated home theater, so off axis viewing is something that happens quite a bit.
Also with further researching I see mention of samples. Do these come from dealers or the manufacturer? Perhaps having a grayhawk and a firehawk samples to evaluate could be the way to go. Probably have to go to Dallas or Oklahoma City to find a dealer (both about 120 miles away).
As a side note I am also looking forward to getting a 4k projector, hopefully towards the end of next year when the whole HDMI 2.0, HDCP 2.2 and Rec 2020 colorspace issues are worked out (I know next year could be dreaming). I assume both the Firehawk and the Grayhawk would do well with a 4k picture.
From my understanding of Stewart screens essentially there is 100->grayhawk->firehawk in order of no rejection of ambient/reflected to most rejected.
Reply Screens
Projection Screens , Stewart Firehawk G3
