The official Carada screen thread. - Page 53 - AVS | Home Theater Discussions And Reviews
post #1561 of 1565 Old Yesterday, 12:13 PM
AlexanderDelarg's Avatar
Quoted: 87 Post(s)
Liked: 115
Originally Posted by Dominic Chan View Post
Did David explain why he recommends the BW over the CCW?
The extra brightness the BW gives over the CCW. He explained that the bulb won't need to be exchanged as often with the BW and one can run their projector in ECO mode instead of high mode (Epson owners). I am sure the CCW is a great screen as well as people have stated on here.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #1562 of 1565 Old Today, 08:31 AM
rlindo's Avatar
Quoted: 127 Post(s)
Liked: 169
The difference between the BW and CCW brightness is tiny unless they changed the BW material over the last 8 years and it is now brighter. I expected the CCW to be a good bit dimmer based on the sample I attached to my BW but when I swapped out the full screen material the CCW looked just as bright and I have my iris setting on my X500 at the exact same setting as I did with the BW.
As I said in my lengthy review of the CCW weeks ago, I really see no reason to buy the BW over it given they are so close in brightness and the CCW produces a superior black level and just has an extra bit of clarity and depth. The CCW's improved black and clarity and depth easily trumps the miniscule increase in brightness of the BW. The BW is a nice screen but the CCW is IMHO simply better.
ROB
rlindo is online now
post #1563 of 1565 Old Today, 08:34 AM
rlindo's Avatar
Quoted: 127 Post(s)
Liked: 169
I guess a 2x4 won't work in this case.
I don't know whether the Carada screen is meant to be taken on and off repeatedly. I don't own one myself, but looking at the installation instruction the frame bottom snaps over the bottom bracket; not sure how easy it is to "unsnap" it.
You don't need to use the bottom bracket if the screen hangs plumb. That and if you don't have any issues with the screen being pushed upwards from below.
ROB
post #1564 of 1565 Old Today, 02:21 PM
silverfx's Avatar
The brightness difference between CCW and BW for my projected image size was enough to go BW.
HT: JVC RS4910, Carada BW 150", Oppo 103D, Onkyo 876, Polk RT
Panasonic 65ST50, 55ST50, 50PZ85U
silverfx is offline
post #1565 of 1565 Unread Today, 07:11 PM
rlindo's Avatar
Quoted: 127 Post(s)
Liked: 169
Did you first have the CCW and then swapped it for the BW?
ROB
Reply Screens
Projection Screens , Panasonic Et Lae700 Replacement Lamp For Pt Ae700u
