EluneVision screens - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
Old 01-22-2014, 07:46 PM
xb1032's Avatar
Liked: 26
Originally Posted by cardoski View Post
Ok I am a meat head, there was a heat vent blowing between the screen and the PJ eek.gif . Can't believe I didn't think of that. The screen is perfect.
I had the exact same problem last year right after I bought a Sony projector. I didn't see the issue immediately either. smile.gif
xb1032 is offline
Old 01-22-2014, 08:22 PM
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Ok I have a strange issue with my EluneVision 4k reference 1 gain screen. Initially I thought it was my projector but now that I have a new PJ I can now I am almost certain it is the screen. Which is unfortunate because I sent my first PJ back 2 times.
On a portion of the top left side of the screen, about the size of a pizza box, is a image distortion that looks like swirling heat waves. Now my JVC is on an open shelf with lots of breathing room, so there is no heat build up. It really only shows on white or light color scenes but is rather distracting. I lived with it, because I was convinced my old PJ was the issue, in fact I went and got a different totally open shelf when I got the new PJ. Has anyone else experienced this? I was also curious how one cleans these screens ?
Is it coming from your HVAC?
When my heat comes on I get the same distortion. If it's "moving" it can't be from the screen.
***edit...sorry didn't see your post*** glad you found it
cardoski likes this.
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
Old 01-23-2014, 01:21 PM
cardoski's Avatar
Quoted: 1174 Post(s)
Liked: 1147
Curious if anyone here has the Elunevision 4K 240 2.4 gain screen? I want to pair it with my JVC X500 in a light controlled room, I am shelf mounted just above eye level. I would like to be able to watch TV with some rear lights on, but more importantly I want to be able to clamp the Iris of my PJ all the way down, increasing black levels but still have the similar light output of my current Elunevison 4K 1 gain screen. Right now I have my Iris half way down and the black bars in movies nearly disappear but it is to dim. My screen is nearly as wide as my room and my couch, which is the only seating, is with in the edge of the screen.
It's always in the last place you look.
cardoski is offline
Old 01-24-2014, 09:22 PM
Marco T's Avatar
I am very curious about the Vivid Pro-Cinema White - 2.4 Gain material too, especially how it compares to legacy HP 2.8 da-lite material. I currently have a 70X70 Da-lite Model B High Power 2.8, which I love. But I am setting up a new Home Theater room , and will need a bigger screen.
Would hate to give up the pop of the HP screen. But I won't stand for an uneven picture, as my current HP 2.8 has very little texture and no hotspotting. Still it would be nice not to have to install black velvet curtains on all room surfaces to get a decent picture.
Marco T is offline
Old 01-26-2014, 06:47 PM
roxiedog13's Avatar
Quoted: 1297 Post(s)
Liked: 545
I have two samples of the HP 2.4 and one sample of the Elune 2.4. They are the same, in appearance and performance. The Elune advertises a wider viewing cone, I do not see it personally. In my opinion these are the same materials from the same
company and as far as I recall the Elune comes from China. Is the HP made in China?? Other than being identical in every way....hard to tell wink.gif
Dedicated Theater: Sony VPL VW 675ESB & JVC X950RU/RS600 , Panamorph DC1 Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Anthem 1120 AVR , 7.2.4 Atmos, Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: (4000 watts peak) Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is online now
Old 01-27-2014, 02:48 PM
DaVinci2's Avatar
HI Cardoski...same here...Would like to pair it with my eventual JVC X700 with this same screen but with a little ambient light (open concept living room). Wondering as well is anyone here has paired this screen with either the X500 OR X700?
The screen would be 2.35:1 - 121 W x 59 H...Thanks !!:)
DaVinci2 is offline
Old 01-28-2014, 11:32 AM
Marco T's Avatar
Can you get the Elara screen with reference 4k material? If so, what would be the price bump for a 106" inch 16:9 reference grey? Although I appreciate the luxury of the 5" frame on the reference, its just a little too big for the 106" viewable 16:9 image in my space. The Elara could be made to fit. I would not really want to drop to 100" if at all possible. My viewing distance will be 10-14 feet. Projector is w1070, full light control possible but some slight leakage expected (the HT room is near the bar/sitting room, partial wall but no door.)
Marco T is offline
Old 01-28-2014, 11:38 AM
thethirdnut's Avatar
@MarcoT - that is exactly what I have. 106" Reference 4K 1.0 gain material inside the 3" Elara frame...works well.
thethirdnut is offline
Old 01-28-2014, 11:56 AM
DaVinci2's Avatar
Hi Marco...I believe it is possible as mention by "thethird nut"..LOL...However, i did make the request...should get an answer soon. Ciao!!
DaVinci2 is offline
Old 01-28-2014, 01:59 PM
DaVinci2's Avatar
Hello Again Marco...Here is a quote from Dave at Eastporters:
"Some have 5", some are 3.5", it just depends on the screen, but we can pretty much get any screen with 3.5" frame.
5" comes on Reference Studio 4K 100 Screen only but we also have 3.5" frame for the Reference Studio 4K 100 screens as well."
So there you have it...they are located in Hamilton Ontario..I believe it's not too far from where you are.
Good Luck!!
DaVinci2 is offline
Old 01-31-2014, 12:04 PM
Marco T's Avatar
@roxiedog13,
Is your material from Elunevision the Vivid Pro-Cinema White 2.4 or the Reference Purebright 4k 2.4? If I can get a slightly longer ceiling mount a high gain screen would probably be my best bet. even the draper screen selector agrees wink.gif Looks like the HP 2.4 fabric would work very well for me.
Marco T is offline
Old 01-31-2014, 09:32 PM
nickoakdl's Avatar
Quoted: 76 Post(s)
Liked: 62
Elunevision used to advertise the same viewing cone as Da-lite for their high gain screens, and then one day I went on their website and their viewing cone somehow jumped to 100 degrees. I also had samples of HP 2.4 and Elune's 2.4 and agree that they are identical. I bought the Da-lite Cinema Contour for the simple fact that they are honest in their marketing of their screen, unlike EluneVision.
nickoakdl is offline
Old 02-01-2014, 01:29 PM
aab1's Avatar
Quoted: 49 Post(s)
I've had my 106" EluneVision manual pull down screen for a few weeks now and had been too busy to mention a major problem I had that others might also.
The screen was advertised as 99" wide with the casing, so I thought it would be fine to install between 2 walls that are 101" apart, but when I got it it didn't fit because the 99" they state does not include the soldered on 1" bracket on each side, in reality it's 101" wide and was literally 1/16" too long to fit between both walls. Luckily there's a Window on one of the walls so I ended up having the screen end inside the window frame and amazingly it left just enough room to install horizontal blinds so it ended up working but others might not be so lucky. By the way the room isn't that narrow, there's a closet at the opposite side of the window which reduces the width to 101" for the depth of the closet.
aab1 is offline
Old 02-01-2014, 01:33 PM
aab1's Avatar
Quoted: 49 Post(s)
Something else I wanted to mention, I have my screen pull down in front of a desk and I had my phone behind the desk so each time it rang I would rush to lift the screen up (not retract it, literally lift it up into a U shape) and I ended up getting a major "crack" in the middle of the screen. I read that using a heat gun would make it disappear and it did, but I left it slightly too long and it "stretched" the screen in that area and now it's slightly wavy, better than the crack and not very noticeable, but is there a way to solve this or will it fix itself? It seems to be getting better as days go by.
I obviously now always retract it properly and put another phone elsewhere so I can answer calls without having to pull the screen up/
aab1 is offline
Old 02-03-2014, 04:39 AM
roxiedog13's Avatar
Liked: 545
@roxiedog13,
I believe it was the PureBright 4K 2.4 but will have to confirm .
Old 02-03-2014, 04:46 AM
roxiedog13's Avatar
Liked: 545
Most manufactured screens are measured by the case and any attachment brackets are additional. You have to look at the detailed drawing it usually will show brackets that are not included in the case measurement.
Not sure how they can get away with this as it is false. The standard should be to give the total width with mounting hardware .
Old 02-03-2014, 07:22 PM
roxiedog13's Avatar
Liked: 545
@roxiedog13,
It was indeed the Pure-Bright 4K that I have. My guess is the Vivid is the old Da-Lite 2.8 glass bead and the Pure-Bright the new Da-Lite 2.4. I cannot confirm this but I can say from my testing there is no difference between the Da-Lite HP2.4 and the Elune Vision Pure-Bright 2.4 .
Old 02-03-2014, 10:31 PM
Marco T's Avatar
Thanks Roxiedog13, the Pure-Bright 4k is way out of my price range.
Marco T is offline
Old 02-15-2014, 10:40 AM
Angus.Young's Avatar
I'm considering getting a 100" fixed,
however I have some questions.
My house is a 4 level split, and the screen would be going into the basement. The problem is the access to the storage/crawlspace would be behind the screen.
How easy would it be to remove the screen for access to the door? Well mini door really but anyway...
I wouldn't have to be in there a lot.. probably 1-2 times a month at most.. but I would need access and moving the access unfortunately does not work because it is a small space.
I was thinking I could mount the screen on some kind of easy disconnect hooks or something and then just set it off to the side when I need to get in.
Does this sound feasible? Is the screen strong enough to put up with this kind of movement without causing any harmful affects?
Thank You!
Angus.Young is offline
Old 02-15-2014, 10:57 AM
ash_man's Avatar
Quoted: 57 Post(s)
Liked: 31
Two thoughts come to mind, although I have to tell you I am not the handy type and would have no clue how to build what I am about to suggest.
Is there enough room on the wall for you to build some sort of system that would allow the screen to slide on rails, so you could slide it out of the way to gain access to the door to the crawlspace? Or perhaps if the wall is big enough you could slide the screen up?
My other thought is to build a frame with hinges of some sort that would allow you to lift the screen up from the bottom in the same way you would lift a garage door, out and up from the bottom?
I don't know how feasible these ideas are, but I thought I would share them anway
BenQ W1080ST
125" Elite Screen
Denon AVR S710W
Paradigm Home Speaker set 5.1 Cinema 100
Harmony 650
Asus Chromebox
ash_man is offline
Old 02-15-2014, 01:52 PM
albert-canuck's Avatar
Quoted: 12 Post(s)
I would get a motorized screen as the easiest solution.
albert-canuck is offline
Old 02-15-2014, 08:38 PM
Motorized might be best option but it's more money and more things to break.
No room for it to slide to the side. Flip up could possibly work but I'm not to handy either frown.gif
Anyone know the performance and look of a motorized screen vs fixed? I'd be somewhat concerned about the increased chances for wrinkles and it not being 100% tensioned? Or is this nothing to worry about?
Old 02-15-2014, 09:52 PM
Quoted: 12 Post(s)
I have had my motorized 92" EluneVision screen for a couple of years now and have had no problems at all. The motor works like new and there are no wrinkles in the screen, the tension seems to still be uniform. A projected image looks fine but I wonder if the higher priced reference screen would be better? I don't notice any texturing or hot spots but perhaps the other screen would show more detail? It is hard to tell without comparing them side by side.
I also have a pull down screen of the same size but the motorized one is much more convenient.
Old 02-16-2014, 10:09 AM
ash_man's Avatar
Quoted: 57 Post(s)
Liked: 31
Do you leave your motorized screen down most of the time, or do you have it rolled up when not in use?
BenQ W1080ST
125" Elite Screen
Denon AVR S710W
Harmony 650
Asus Chromebox
ash_man is offline
Old 02-16-2014, 11:05 AM
Quoted: 12 Post(s)
I usually roll it up, though for the past week it has been down. I watch 4-5 movies a week for the past couple years so it has been up and down quite a few times. Never had a problem and the motor works just as smoothly as when I bought it.
Old 02-20-2014, 06:46 PM
Just add water and stir
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
Milosh,
When do you plan to release a product that offers retrofit masking for 2.35:1 on a 16x9 Reference screen?
I dream about this for my screen...
Thanks so much for answering.
Aaron
zuluwalker is offline
Old 02-20-2014, 08:08 PM
N2Sand's Avatar
Does anybody know how to make the 12V remote trigger learn the screen code. I just received and installed my 120" Reference Studio 4K AudioWeave tensioned screen and the remote trigger doesn't activate the screen out of the box. I don't see a hole in the screen end cap like the remote instructions indicate and pressing the up and stop buttons on the wall trigger per the screen instructions doesn't seem to do anything either.
N2Sand is offline
Old 02-23-2014, 09:07 AM
simpleHT's Avatar
Originally Posted by zuluwalker View Post
Milosh,
Aaron
Monoprice has that.
simpleHT is offline
Old 02-23-2014, 03:54 PM
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
Originally Posted by simpleHT View Post
Monoprice has that.
Thanks for the tip. I took a quick look but can not find a retrofit masking screen for my current screen. Can you send me a link please? All I could find were screens that had the masking options built in.
Old 02-23-2014, 04:37 PM
simpleHT's Avatar
^^ Sorry, probably I misunderstood you. MP has framed screen with build-in masking mechanism (they call it multi-format), as you noted. If you want masking for existing fixed frame screen, I think it can be DIY.
simpleHT is offline
Projection Screens , Epson , Epson Emp Tw600 Replacement Projector Lamp Elplp35 V13h010l35
